Need help removing Intake Manifold on Max 90
Hello,
I pulled upper and lower manifold, took out the fuel injectors rail, now i need to pull out the Intake manifold , i took out all 8 bolts ( 4 nuts and 4 bolts ), but i have no luck. it's stuck. I'm trying to change the gaskets, because they are leaking oil right to the injectors causing my car to have bad starts due to oil in the injectors.
any ideas please help
please help
thank you....scrui
please help
thank you....scrui
Originally Posted by scrui
mygreenmax94 is correct, it's called the Intake manifold, i need to pull out the whole thing, the book states to lift it out. i soaked the sides with wd40.
any ideas
any ideas
If you replaced your injectors,then you took the intake manifold off..
You got a pic of it?
how do i attach a pic on a reply
2. Go here http://www.tinypic.com/
3. Browse your pictures for the pic,then upload the pic..
4. Copy the img link..
5. paste it in your post...
Originally Posted by therealgoon9
You'll probubly need to pry it with a screw driver...
I hope that is all I will need to pry this thing up, because just with sheer strenght, didn't work at all.
I just thought maybe there's was something else i needed to loosen to get this thing out, that i wasn't aware of it.
Does it even wiggle at all?
Originally Posted by Josh
I've never pulled apart a VG but what about the passages where the coolant flows through, did you unbolt that part?
Update -
I was able to pry the Intake, I took your advise MygreenMax94.
I used a crow bar and placed were you told me and with a little pressure,
it loosen itself.....thanks.
man, no wonder the injectors were full of oil and gunk , the gaskets were shot. this will defenitely make my ride much smoother going forward.
thank you.
thank you.
The Frye
Sep 2, 2021 11:03 AM
