Shopping list purchased!
1 x Valve Cover Gasket Set
1 x Power Steering Hose
1 x Power Steering Pump without Electric Control
1 x Rack and Pinion
1 x Oil Pan End Seals
1 x Oil Pressure Sender
1 x Full KYB strut set
1 x Front Control arm set
6 x NGK Iridiums
Okie. Heres my shopping list. I gotta know what I should go buy as far as greases, oils, Etc...
I never trust those auto part store guys..
I dont know if I will need anything for the struts, but I remember always using high temp silicone on gaskets? I need a recommendation on that.
Also for the spark plugs, you use anti-seize right? any brand is fine there probably.
If you guys can let me know what tubes of what I will need, Thanks!
~J
1 x Rack and Pinion
6 x NGK Iridiums
~J
Will take me a day =) Thanks.
I also meant to ask what kind of goop I should use on the slider for my moonroof and antenna. The antenna is making an awful sound on the way down... Moonroof is just old aftermarket install and I want to maintain it.
03-12-2020 12:06 AM
