Front Engine Oil Seal Leaking
Old Sep 18, 2006 | 09:19 PM
wrkllc's Avatar
Is there an under sized front oil seal or sleave available for the crankshaft? with over 401K miles mine is leaking, at the last timing belt and seal change I noticed a small groove in the shaft. If I tighten the belts too much it leaks more, so I have to make the belts even. There is not room to move it farther in or out.
It mainly leaks when I stop and it is about a three inch spot, but oil is blowing back and getting all over.
Old Sep 19, 2006 | 06:14 AM
DanNY's Avatar
Ad·min·is·tra·tor
if there's a groove on the crank i'm not sure how to seal that up. you can go to the parts store/dealer and check out their stock. maybe they have something for you. perhaps you can throw on a thin sleeve on the crank snout where it contacts the seal to keep the oil in?
Old Sep 19, 2006 | 05:58 PM
Governor's Avatar
I
suspect that the sealing surface (where the crank seal actually mates
with the crank)on your crankshaft is what's called "seal worn." This is
where the seal has actually worn a groove into the crank snout. This is
easily repaired with a sleeve that should be available locally at any
decent auto parts store. Most vendors call it a "Reddi-Sleeve." http://www.microsleeve.com/csrs.html A
little trick I use when installing seals like this is I smear a very
light coat of Permatex 2B (the non-hardening stuff) on the OUTER edge of
the seal. This will assure the seal does not leak around it's outside
diameter or will not pop out at a later date.
Good luck
Old Sep 21, 2006 | 04:01 PM
wrkllc's Avatar
Originally Posted by Governor
I
Good luck
Hey thanks for the tip I will try it at the next T belt change in about 18K as I can live with the leak, just have to keep an eye on it and cardboard under it.
Old Sep 21, 2006 | 04:53 PM
Hectic's Avatar
401k? retire it
Old Sep 21, 2006 | 06:55 PM
Governor's Avatar
Originally Posted by Hectic
401k? retire it
Oil is cheap...why retire it...run it till it stops
Old Sep 22, 2006 | 03:55 AM
89blackse's Avatar
"and falling like a rock"
hellz yeah
Old Sep 22, 2006 | 07:57 AM
internetautomar's Avatar
mod or sell?
401k? retire it
:roflcopter:
though apparently it went over most heads here
Old Sep 22, 2006 | 01:18 PM
DanNY's Avatar
Ad·min·is·tra·tor
:roflcopter:
what about 403B's?
Old Sep 22, 2006 | 01:51 PM
mod or sell?
I'm no accountant.
Old Sep 22, 2006 | 06:44 PM
Governor's Avatar
:roflcopter:
Pretax money from your pay check will buy lots of oil...run it till you can draw your retirement or till she stops!
Old Sep 24, 2006 | 08:51 AM
wrkllc's Avatar
401k? retire it
Thats because, 401K's are old news Now its a Roth 401K lol.
maxima = 401K and leaking.
401K = $159K taking the slow road.
Roth 401K = Growing by leaps and bounds, LOL.
MAXSE5SPD
Aug 23, 2015 12:06 PM
carlosvq30
Aug 17, 2015 11:32 AM
Balkins
Aug 12, 2015 06:39 AM
