Clutch question
Old Sep 26, 2006 | 04:13 PM
xx-Marshall-xx's Avatar
kthxbye2u
Clutch question
if the springs on the pressure plate are worn out, would it effect/explain the loss of pressure in the hydrolic lines of my clutch master/ slave/ pedal?
because ive posted maybe 3 threads about my clutch problem and this is what the guy said
reason he said was because:
when he started the car and had to pump the clutch (to get pressure in order to depress the clutch) he put it in 1st and let go of the clutch a little and heard a loud THUD. sooo when i came to pick it up he told me and i said to him that i had that happen 2 times to me
discuss
Old Sep 26, 2006 | 06:49 PM
goon9's Avatar
If you need to pump it, either your master or slave cylinder is leaking. Replaced BOTH. Change that first, then proceed.
Don't get a slave from autozone! (I bought 3, they all quit or leaked from the start.)
I got my GOod one from napa.
Old Sep 27, 2006 | 07:03 AM
2Legal4Me's Avatar
yep autozone and kragen /smuckers/checkers all suck they will leak or eventual sooner than normal fail leaving you stranded. and also maybe your adjustment screw underneth your dash to master cylinder has too much play not allowing the fluid to remain pressurized.
Old Sep 27, 2006 | 01:04 PM
kthxbye2u
wheres that? ive looked for something like that before
Old Sep 27, 2006 | 01:39 PM
blackandwhite's Avatar
To them I'm like an idol
co-signing on the thing about bad slave cylinders from autozoe, currently on my 3rd in 6 months
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 20, 2015 11:46 PM
pears
Sep 18, 2015 05:25 AM
Johnny9595
Sep 3, 2015 05:18 AM
