Engine temp sensor
Old Oct 23, 2006 | 12:07 PM
Maxteca's Avatar
Engine temp sensor
My ecu put out the code for the engine temp sensor. Shouldn't my cel be on?
And would a bad engine temp sensor affect gas mileage because I get maybe 15mpg on the highway.
Old Oct 23, 2006 | 12:13 PM
Greeny's Avatar
¯\(°_o)/¯
Sometimes the ecu will just illuminate the light for just a few seconds,and then store the code..
Yes it could effect gas mileage iirc...
Old Oct 23, 2006 | 12:17 PM
Maxteca's Avatar
The cel never comes on. Maybe the cel is burned out
Old Oct 23, 2006 | 12:18 PM
Greeny's Avatar
¯\(°_o)/¯
Maybe?
Old Oct 23, 2006 | 12:40 PM
92 Max's Avatar
The CEL should illuminate when you turn on the ingnition, but before you hit the start. If not the bulb is burned out.
Old Oct 23, 2006 | 01:00 PM
Mizeree_X's Avatar
Getting back to his roots
I think your engine could be on fire and the CEL wouldn't go on. The CTS can definitely affect fuel economy, so replace it immediately. Autozone sells a replacement with a warranty for $16 I think.
Old Oct 23, 2006 | 01:03 PM
Greeny's Avatar
¯\(°_o)/¯
I have had my maxima for 6 years and have yet to see it..
Old Oct 23, 2006 | 01:07 PM
Maxteca's Avatar
Thats funny you said that my 87 max had a injector recall and caught on fire and the cel did not come on.
Old Oct 23, 2006 | 06:44 PM
AndyVE30DE's Avatar
My light never came on either but it gave me the code. I had a bad sensor and connector, make sure your wires are in good shape. I have a VE and my car was guzzling gas has if it was a big boat. I also had power loss in the midrange. Replaced the connector harness and sensor and the car is running like a champ.
Old Oct 23, 2006 | 08:17 PM
Cliff Clavin's Avatar
Way out West
My temp sensor threw a code (no CEL) and my fans would turn on and off randomly. It also ran rough and the idle surged, but I also had a gunked up IACV. It didn't happen long enough for me to notice poor mpg, but I am sure that was in there, too.
I have had the CEL light turn on, but that was shortly after the JDM install and the ECU turned up a code 5-5. It never ran bad and I did not find anything wrong. It is like a "reverse" CEL.
captchaos
Mar 15, 2016 12:18 PM
220k+ A32
Sep 11, 2015 02:18 AM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
