Will new headers work...
Old Dec 13, 2006 | 11:54 PM
paesantom's Avatar
I just bought a set of pacesetter headers and its not looking to good for my ws y-pipe. i'm wondering if i have to use all the parts from the pacesetter headers, or will my y-pipe be able to be used. Another thing which set up is better. Would it be better if i just sold the y-pipe and used the pace setter set up? i need all the advice i can get...
Old Dec 14, 2006 | 04:59 AM
goon9's Avatar
You can' use your Y with it. It's either stock manifolds with the Y. Or Pasetter all the way to the cat.
If you use the pasestter, it would be smart to keep the Y just in case there's a problem with the pasetter in the future.
Old Dec 14, 2006 | 11:15 AM
jonmandude's Avatar
Keep the WSP Y and sell the Pacesetter crap.
jonmandude's Avatar
Old Dec 14, 2006 | 11:49 AM
paesantom's Avatar
well the the crap was a christmas present... from friends who are honda freaks so they didnt know any better but i'll give the headers a whirl and see whats up thanks guys.
paesantom's Avatar
Old Dec 14, 2006 | 12:14 PM
Alex_V
then you cant loose other then some time. Put them on make sure they don't leak, then get it dynod then put the stock manifolds and WSP Y pipe on and do the same. Also let us know how it fits when your done.
~Alex
Old Dec 14, 2006 | 04:06 PM
Matt93SE's Avatar
STFU n00b!
~Alex
Errr, why not save some labor and dyno BEFORE installing the pacesetter stuff?
(we all know it'll be coming back off shortly, but just in case.... )
Old Dec 14, 2006 | 07:26 PM
Alex_V
Good some ones paying attention.....I realized after I posted and I was too lazy to change it
~Alex
Old Dec 14, 2006 | 11:53 PM
paesantom's Avatar
well my stock manifolds leak so i'm pretty much like anything to fix the leak is better than nothing... so the headers will help somewhat
Old Dec 15, 2006 | 08:10 AM
traxtar944's Avatar
Would be lost w/out the org
if the stockers leak I'm guessing you have bigger problems....like broken studs. Oh well, at least you'll be spending alot of time on that area anyways.
Old Dec 18, 2006 | 11:24 AM
Badman_Maxima's Avatar
ahhhh $h1t broken studs, been there done that, its a real pain in the **** lol!
Old Dec 18, 2006 | 01:04 PM
paesantom's Avatar
is it a certain that i have broken studs... cause all i want is that crappy ticking to go away...
Old Dec 19, 2006 | 06:06 AM
oh you got the ticking thing goin, are you sure its coming from the exhaust, I know of the ticking noise from a leaking exhaust, but the ticking noise also comes with faulty VTC, and/or faulty coil / spark plug wiring.
Old Dec 19, 2006 | 09:16 AM
Dhunterx's Avatar
If he didn't write his profile wrong, he's got a 91 SE. He shouldn't have any ticking of the VTC varity because he's got a VG.
Just replace your broken studs, or have someone remove them. That's the majority of your noise problem.
Old Dec 19, 2006 | 09:54 AM
ColombianMax's Avatar
Muahahahahahaha!!! if you think its the manifold...think again!
Old Dec 19, 2006 | 11:49 AM
paesantom's Avatar
so exaclty how hard is it to do the exhaust studs
Old Dec 19, 2006 | 01:50 PM
Jeff92se's Avatar
I'm needing a caw
What the hell are those pics of?
Old Dec 19, 2006 | 02:07 PM
goon9's Avatar
Thats great, I knew you could do something like that!
Old Dec 19, 2006 | 03:24 PM
Jeff, those are my old studs that were pulled outta my car.
Paesantom, the ease of this job depends on skill, equipment, and time. I didnt do it, mechanic did but I stood next to him all 6+ hours of labor watching how it was done (PITA) As long as you have welder, lift that allows to walk under car and enough tools you should be fine.
Hey Goon, what do you mean by "I knew you could do something like that"? is there something I'm missin here?
Old Dec 19, 2006 | 03:27 PM
Jeff92se's Avatar
I'm needing a caw
odd.
When the stud was poking out, I just grabbed it with something and turned. But if the stud is below the head surface, I don't see how you could have got anything welded to them.
Old Dec 19, 2006 | 03:38 PM
Most of them were below surface, and yes he just welded with a real fine and pointy thingy..took 6 hours but he got it done and looks like Nissan uses the turbo manifold studs for the maxima too. the only thing buggin me now is that the bolt that holds my distributor down isnt grabbin to well and my timing was messed up after tuning it right. its not the bolt but rather the hole..hmm what to do? I got a bigger one in there but still doubtful oh that fix
Old Dec 19, 2006 | 10:11 PM
paesantom's Avatar
so then i'm not tackling this job with the exhaust studs.... how much was it to have your studs done. i think i may bring it to my local nissan dealership
Old Dec 19, 2006 | 10:15 PM
NO!!! Nissan wanted 800 bucks from me to do the studs. I paid this guy $200 labor and I bought OEM parts for $115 hell he even changed all 6 y pipe studs
Old Dec 19, 2006 | 11:47 PM
Alex_V
John isnt he charging $300 from now on? $300 is about the cheapest your going to get unless you do it the standered drill and ezout method. Theres a tonnnn of posts on the topic just search.
~Alex
Old Dec 20, 2006 | 12:46 AM
Yea but he asked how much I paid not how much it would cost him. Yes the mechanic who did my studs found out that the A/C compressor had to be removed for front studs after he quoted me at 200 for labor...so as of now if anyone near is interested in his work..he'll do studs for $300 when you bring parts. so its pretty much 415 parts/labor
Old Dec 20, 2006 | 09:43 AM
paesantom's Avatar
wow thats expensive... really dont wanna drop that kinda dough on exhaust studs... i could have my cams or my underdrive pulley for that kinda money. i really hope you guys are certain.
Old Dec 20, 2006 | 10:32 AM
Alex_V
Well if you look at your exhaust manifolds you'll have your answer. For the back get a mirror or just use your hands and feel for holes where the studs would be. Thats a broken stud.
~Alex
Old Dec 20, 2006 | 12:52 PM
So you're thinking of modding a messed up car? that doesnt make sense..how about fixing what wrong THEN upgrading it
Old Dec 21, 2006 | 11:54 PM
paesantom's Avatar
i'll check it out thanks for all the info you guys have been alot of help.
Old Dec 23, 2006 | 12:24 PM
DaWifey's90's Avatar
what can my max do for me
anyone have the size / specs of the exhause hardware? i'd like to get a set of arp's before i get into this mess.
i'm showing they're 10mm 1.50 x 77mm....can anyone confirm or deny?
Old Dec 23, 2006 | 12:34 PM
Alex_V
No they are 8MM, but some people have tapped them out to 10's as 10MM should never break. If you order the stock VG33 studs you should be fine.
But also ARP 8mm's would be a good way to go too. If I keep my max thats what I'll do.
~Alex
Old Jan 18, 2007 | 11:48 AM
morides4chefs's Avatar
morides4chefs
I just did "pacesetter"header,complete exaust and stainless high flow cat.Fit and sounds great.
Old Jan 18, 2007 | 12:02 PM
Greeny's Avatar
¯\(°_o)/¯
Got any pics of all your work?
KabirUTA13
19
Oct 17, 2015 02:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
ac max 92
Sep 17, 2015 07:35 AM
Maxboy23
Sep 4, 2015 06:04 PM
