Max still has electrical issue
Old Jan 6, 2007 | 08:26 AM
Majik's Avatar
I'm back at the 90 Max SE trying to figure out the electrical problem, but so far to no avail. I did find a broken wire that was attached to the bolt/hangar on the front of the catalytic converter...any idea where the other end should attach to? Would this broken wire cause my car to blow the fuel pump fuse every time I try and shift into first or second gear? Any help as usual is appreciated!
Old Jan 6, 2007 | 03:30 PM
Maxima Man's Avatar
No it will not effect your fuel pump. It is a ground for the 02 sensor !
Mabey your fuel pump wiring insulation has been worn through and is shorting out and blowing fuses>>>>....?
Old Jan 6, 2007 | 04:23 PM
Greeny's Avatar
¯\(°_o)/¯
I may be the neutral position switch on the transmission...
Old Jan 7, 2007 | 05:07 AM
Majik's Avatar
So if I understand the diagram...that sits on top of the transfer case?
Old Jan 7, 2007 | 05:09 AM
Majik's Avatar
I have the back seats completely out of the car...and the wiring to the fuel pump looks fine. I have drained the tranny fluid and re-filled and it is still shorting out the fuse for the fuel pump whenever I push the stick to the left to put it into first or second gear.
Old Jan 7, 2007 | 05:11 AM
Majik's Avatar
So MaximaMan will that ground for the O2 sensor make it not run as good as it could? Thanks for the slap to the back of the head...I needed it.
Old Jan 7, 2007 | 05:50 AM
Greeny's Avatar
¯\(°_o)/¯
Transfer case? This isn't 4X4chevy.org.
No,the sensor is in the back of the transmission,just follow the harness wire from the top down to it's end...
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Maxima30
Sep 7, 2015 06:13 PM
Hailstatejig
Sep 2, 2015 06:52 AM
