Weird engine miss - vg
My car starts and runs well from cold - But if I go a long ways and park for a little while it starts missing badly when I restart it. Or if I go a short ways and park in the hot sun (texas in july), it does the same . Any one with some ideas.??
Vapor lock ???
Originally Posted by dafiremaster
have a mechanic throw a timing light on it. Also other things to check would be the spark plugs/ignition system. or a vapor lock issue.
I initially thought that it was a vapor lock, but all the reading material on the net says that vapor lock is a thing of the past with fuel injection engines. Could a failed gas cap do this ?
You have got to be joking? right?
I've never had any experience with a failed gas cap, but i've been told before that fuel injected cars run like crap without a gas cap on. so i suppose that could be a problem.
If the engine is missing, the ignition system is a no brainer to look at.
Fuel injection has cut down on the vapor lock problem, but it can still happen. How long has it been since you've changed your fuel filter? also you might have some water in the fuel lines. My car has a similar problem, which i've not yet figured out. I can only get it do to it sporatically. It got to the point where i hadnt drove the car at all and my fire department got a code red shooting call. Well it ran like crap. trying to get to the call, and then died on me at the scene. Boy... that was an interesting day. I'm hoping the problem shows back up in the summer, so i can take care of it. Though, with future plans to the car, that problem may not be an issue any more.
Assuming I have some water in the fuel lines - how do I get rid of it ? I did a tune up of everything else about 3 months before this problem started. New sparks, wires, air filter, fuel filter, cap.
No... i'm not joking. Timing can cause an engine to miss. Though typically when the engine is cold. I've seen cases where it affected the engine when it got hot.
On fuel injected cars the gas is constantly circulating from the tank, through the system and back to the tank. The fuel does not stay still long enough to get so hot that it begins to vaporize.
It still can happen! water in the lines, If the fuel filter is clogged, under heat it will produce a similar type occurance.
To get water out of the lines, run the tank about empty. Put 3-4 bottles of isopropyl alcohol in it and run it till it dies.
It's called A-tech skool now right? Just goes to show that some shops still pay more for ppl with experiance than schooling.
Anyway. If there was moisture in the line(which I think is bs because Internetautomart is correct). But IF, it would run like crap ALL the time. It's only doing this after warm up.
Knock sensor? I know they tend to cause problems after warm up.
And about timing. I've set my way retared and advanced, and never missed. The only time was when I was 180 off.
When I ran into a problem like this before, I changed my cap, rotor, plugs and that solved the problem.
The sensor was vapor locked..
ballerchris510
Sep 11, 2015 05:29 PM
