Transmission overful??? whats the deal spray @ WOT
Old Feb 2, 2007 | 10:56 PM
Gun5's Avatar
new clutches/band flush..> Tranny.. car hasnt seen street for 7-8 months.. full tune up and such
Well I put the new tags/plates on the maxima earlier today and took it for a drive shifts great @ 6 grand and just driving around i noticed though @ WOT driving transmission fluid sprays out of the open atomsphere tube that hooks to where the solenoids and **** are
so i checked the dipstick to see if the cars fluid was full on the tranny stick it was 8-9 inches up.. so i brought it home and parked it infront of my house. Pulled the vent tube on the tranny stick and it starting pouring fluids out of the dipstick (Doh) so i brought it to level land and it stopped so im pretty confused how to get a accurate reading as far as how much fluids in it and why its spraying??
Told my friend to drive it around lightly since he needed the car since its already his
Old Feb 3, 2007 | 10:23 AM
Gun5's Avatar
bumptt
Old Feb 3, 2007 | 10:49 AM
Alex_V
Proper way to check tranny fluid is drive around for 15-20 minuets to get it hot, put it in drive and with the ebreak on and a brick to stop it (or some one else to hold the brake) and then check the fluid with the car running.
If its as high as you say you need to drain some before its driven any more. Its very bad for the tranny.
~Alex
Old Feb 3, 2007 | 01:41 PM
Gun5's Avatar
~Alex
well i did empty it to recheck my level i emptied like 7 quarts and put 7 back in but theres some still in the tranny/converter (like 2-3 quarts) it has to be overfull HOW MUCH DO I READD AFTER IT STOPS DRIPPING? I forget how much converteres/tranny usualy hold after a drain need to know ASAP todo later today
thanks, Ryan
Old Feb 3, 2007 | 02:02 PM
Alex_V
WTF are you trying to say? Use punctuation and paragraphs.
At this point just check the tranny fluid as I stated before. Then add or subtract fluid as needed. Common sense man...
~Alex
Old Feb 3, 2007 | 03:59 PM
Gun5's Avatar
~Alex
ya I was kinda
I already drained this thing once (drained 5-6.5 quarts) and put it back in Im gonna start draining it by .5 quart inc see if that works will keep yall posted.. besides that shifts fine and running great still says my friend
Old Feb 3, 2007 | 04:32 PM
beefolotti's Avatar
i cant post anywhere else so hey guys im Leo and my 91se transmission just quit working. no noise no slippage....i was turning onto a side street @ 15-20 mph and the rpm guage shot through the roof. i pulled over and the car barely made it to the curb, then ............ exactly nothing. now i have no gears at all. the car runs but stutters a little when shifted into gear and i also checked the fluid(good but burnt and in need of change) and the linkage also good. basically im stuck and theres no telling what id do for help ......=) a guy told me the tranny filter is clogged but in my chiltons and online i could only find poop. this is the best place ive found so........please any help would be great.
Thank You,
Leo
Old Feb 3, 2007 | 04:34 PM
Greeny's Avatar
¯\(°_o)/¯
Thank You,
Leo
Leo.....You need a new transmission...
Regards:MyGreeMax94..
Old Feb 3, 2007 | 04:53 PM
beefolotti's Avatar
Are you sure it cant be fixed? just the thing i diddent want to hear...and SLAP really quick=) man i wish it was as easy as my 71 dart....remove this hit that and its fixed...if there is anything i can do to fix it i'll try it and whats up with the internal clutch or band? i am not afraid to rip it apart. i have done a few manual trannys and my 71 auto tranny....can anyone give me an area to start?
thanks,
Leo...... awseome 2 min reply thx
Old Feb 3, 2007 | 05:54 PM
internetautomar's Avatar
mod or sell?
thanks,
well you're comparing a POS dart with a hydraulically shifted trans to a POS maxima with an electrically shifted trans.
the transmission stil has most of the same features except for the solenoids control shifting rather than a governor/servo/hydraulic thingy.
if you were able to rebuild a 727 you can rebuild the RE4F02A in your VG. Same principles apply. it's just a little harder to find a rebuild kit for.
Old Feb 3, 2007 | 06:17 PM
beefolotti's Avatar
sorry, i did not mean to compare the two. so could the solenoids have fould up?....the last guy just said get a new tranny....i know it can be fixed its 3 years old. they put in a new one when i bought it 3 years ago. i dont know much about these electric transmission thingys... i know about the 727 for my pos dart...( it puts the maximas tail between its legs =) Well a 440 twin 4bbl puts most tails that way....=)anyways i took the tranny pan off and it has a bank of solenoids and electronics on top .would the self diog for the tranny posted here work on my 91? that would help us all if it did.
Old Feb 3, 2007 | 07:04 PM
mod or sell?
it should work for your 91 as well.
Old Feb 3, 2007 | 10:13 PM
beefolotti's Avatar
sweet i will bring it up and post my results.....never torn into one of these is all.....thanks for help..Leo
Old Feb 4, 2007 | 03:16 PM
maximagician's Avatar
[QUOTE=Alex_V]Proper way to check tranny fluid is drive around for 15-20 minuets to get it hot, put it in DRIVE and with the ebreak on and a brick to stop it (or some one else to hold the brake) and then check the fluid with the car running.
you mean park?
Old Feb 4, 2007 | 03:20 PM
i.i was turning onto a side street @ 15-20 mph and the rpm guage shot through the roof. i pulled over and the car barely made it to the curb, then ............ exactly nothing. now i have no gears at all. the car runs but stutters a little when shifted into gear Thank You,
Leo
Sounds like the torque converter is stripped out where the trans shaft splines meet the converter splines, have someone shut off the motor and listen around the bellhousing for the t-converter still spinning a little
Old Feb 4, 2007 | 04:10 PM
Alex_V
[QUOTE=maximagician]
you mean park?
LOL yea I ment PARK. I was thinking of not typing park and i ended up typing it lol.
~Alex
Old Feb 4, 2007 | 07:31 PM
Gun5's Avatar
talk about thread jack
Old Feb 4, 2007 | 07:54 PM
vansskaterfreek's Avatar
if your tranny broke, you might be hearing little peices of metal grinding in there......if you hear that, it is probably your tranny, if not, its probably your torque converter...
Old Feb 9, 2007 | 09:30 AM
beefolotti's Avatar
i love u guys....... i was outta town since last post.....grandpa passed in texas...=(.....thanks 4 info and im on it.....will post results to hopefully help out someone else
thanks
Leo
Old Feb 13, 2007 | 08:35 PM
aussie983's Avatar
BTW make sures its parked on a level surface. I made the mistake of forgetting that and was on a slight incline, and it made a difference. I thought I was leaking tranny fluid(put in synthetic after dino oil) and checked it and it looked low. Later I parked on a flat surface and it was at the correct level.
Old Feb 15, 2007 | 10:38 AM
Darkwing48's Avatar
Thank You,
Leo
Happened to me, I needed to rebuild mine. This happened because of the slipping of the shifter. My gears slipped to 2, sometimes N, while I thought it was D and I drove on the freeway with it.
I thought to check trans fluid, the car has to be off like checking oil. Chiltons suck. It has no chapters about antennas. A true manual should contain all components of the car and not spend the majority on smog emmissions.
(Needs manual to disassemble the Maxima without breaking pieces)
sctludwig
Sep 1, 2022 01:32 PM
crazyespn
Sep 3, 2015 01:30 PM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
