Power steering pump
Old Feb 17, 2007 | 05:35 PM
bvtran's Avatar
94c Big Max
Power steering pump
I went to autozone today and saw they had a power steering pumper puller. Do we need to use a puller to get the pump out?
And how do you guys take off/tighten the pulley nut on the PS pump? that thing keeps spinning
Old Feb 17, 2007 | 06:29 PM
internetautomar's Avatar
mod or sell?
Get a manual please!!!
Old Feb 17, 2007 | 06:54 PM
bvtran's Avatar
94c Big Max
brian, stop being a smart ace. You don't know squat unless you answer my question properly. That's how you prove you know your stuff. I do have the f**** manual but it didn't mentioned anything about the puller. So I was just curious to know if I need it or not so I could gather all the tools/parts for the job.
here read the effn manual and tell me:
http://www.cis.syr.edu/~bvtran/car/rack/st.pdf
Old Feb 17, 2007 | 07:00 PM
«§»Craig B«§»'s Avatar
no, you dont need a puller
check out the stickies - sites like the autozone repair manuals will tell you the whole procedure if you're unsure
Old Feb 17, 2007 | 07:08 PM
bvtran's Avatar
94c Big Max
thanks man, yes or no answer was all I needed. yeah I did read all those junk instructions ..none mentioned it
Old Feb 17, 2007 | 07:30 PM
mod or sell?
Didn't you wonder why it wasn't mentioned?
they almost always mention when any sort of a special tool is needed in the FSM.
so.... no mention = no need
BTW it's a power steering PULLEY puller, not a pumper puller
Old Feb 17, 2007 | 08:19 PM
aminus21's Avatar
I changed the power steering pump on my max a couple months ago. I did not need a puller; a couple of 12mm or 14mm bolts that can be accessed through the holes of the pulley, and it was out..You also have to remove the two hoses that connect to the pump..High pressure hose took a bit longer because the bolt was really tight..
The pump I had came with a pulley, so I didnt need to remove the pulley. But if your new pump doesnt come with a pulley, I recommend removing the pump and the pulley together, then attach a chain wrench (they have rubber ones too), or something similar to hold the pulley in place while you loosen the bolt..
I think it may also be possible to remove the pulley by tightening the power steering belt super tight, and then breaking the pulley bolt loose..but I'd rather use the first method.
If you get stuck lemme know..
lowpost99
Oct 26, 2025 06:53 PM
RWCreative
Sep 21, 2015 11:01 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
rnb754
Sep 14, 2015 11:39 PM
SusieQQ
Sep 9, 2015 12:14 PM
