ECU and RPM help.
Old Feb 26, 2007 | 07:40 PM
Maximahappy22's Avatar
ECU and RPM help.
Hey guys,
This is a flamer question but is the ecu under the dash?
Also i have a window switch for my nitrous but i dont know what output the RPM is on the ecu, does anyone know what prong it is or how i can connect the window switch in a different way?
Thanks.
Alex
Old Feb 26, 2007 | 08:07 PM
Greeny's Avatar
¯\(°_o)/¯
Old Feb 26, 2007 | 08:15 PM
alrighty thanks but can anyone help me with the second part of the problem?
what prong is the RPM input on our ecu, i look on the autozone thing that has the feltons and they dont have it in their diagram... so im stumped.
Old Feb 27, 2007 | 10:20 AM
internetautomar's Avatar
mod or sell?
TACH LIGHT GREEN/BLACK @ TRANSMISSON ECU, See NOTE *4
NOTE *4 TRANSMISSON ECU (Electronic Control Unit) IS LOCATED BEHIND CENTER CONSOLE ABOVE ENGINE ECU, WIRE IS FACING DRIVER SIDE OF VEHICLE IN BLUE PLUG.
PS: only applies to A/T cars
Old Feb 27, 2007 | 01:46 PM
nubiannupe's Avatar
OG Maxima.org Member
Yeah Brian... he's gonna have FUN looking for that wire.
Old Feb 27, 2007 | 06:01 PM
I have a 5spd so that doesnt exactly help me. can i trace a wire from the tachometer to the ecu to splice it?
or does anyone know of another way to get this to work?
Old Feb 27, 2007 | 06:50 PM
mod or sell?
Never said it'd be easy.
I leave the tach wire unhooked alot of the time on my own cars when I do remote starters.
Old Feb 27, 2007 | 06:51 PM
mod or sell?
Just go off the dizzy.
Old Feb 27, 2007 | 08:19 PM
the dizzy?!?! please explain.
Old Feb 27, 2007 | 08:22 PM
mod or sell?
distributor. I've also seen it tapped off of a fuel injector.
doesn't matter really, so long as it is something that gets trigger once everytime the motor turns over once.
Old Feb 27, 2007 | 09:59 PM
How does the distributor count RPMs? and where would i splice it into, plug 1?
This **** is confusing...
Old Feb 28, 2007 | 08:38 AM
mod or sell?
Ok, if you just asked that question then I HIGHLY recommend against do this to your car.
Pick up a manual and learn some basics before you start playing with nitrous.
Old Feb 28, 2007 | 08:55 AM
i figured it out right after i asked the question... i was in one of those panic modes when i dont think and just ask questions.
Everytime the rotor hits the 1st plug it counts a revolution...
So would i splice RPM switch into plug 1?
Old Mar 1, 2007 | 08:09 AM
bump for help!
Old Mar 1, 2007 | 11:44 AM
Alex_V
Ive been in the nitrous forums maybe once, try there. Its in the advance section.
~Alex
Old Mar 1, 2007 | 07:14 PM
noone there has a 3rd gen
Old Mar 2, 2007 | 06:11 AM
nubiannupe's Avatar
I have a 5spd so that doesnt exactly help me.....
Actually, this DOES help you - whether you have a 5sp(which I have) or auto-tragic (which I used to have). The wire is the same for both iterations. I simply made the comment to Brian because it's kinda hard to find (that wire).
But once you find it - and this is going on the premise that you have a DMM handy -meter it with your DMM set to AC voltage and the engine running. You should see the RPM's rise and fall with the press of the gas pedal.
I can give you a "pinout" (location of the wires on the ECU by number) if you REALLY need it. But going by what internetautomar gave you regarding wire color, and what I'm suggesting here should get you up and running without the pinout stuff.
Old Mar 2, 2007 | 05:47 PM
Ok so my thought is to take the speedo out and see if the light green/black wire is there, then hope its right and cut it and slpice it, if its not right then ill just reconnect them and try to trace it.
BTW i dont have a DMM (is that a voltometer thing?) so im just going to have to guess and check.
Thanks for the help!
Alex
P.S. Nupe u going to GG?
gigabyte
Jan 6, 2017 06:05 PM
Need help
23
Oct 2, 2015 08:56 AM
