Wierd steering thing.
Old Mar 1, 2007 | 07:41 PM
Maximahappy22's Avatar
I was driving today and my steering seems loose-ish, like when i barely turn the wheel it seems like there is a loose bolt or something and it isnt super responsive. Like there is play in my steering or something.
Also when i go above 70ish mph my steering wheel sort of vibrates, not voilently but its noticable. I thought it was that springs and shocks but i had them replaced over the summer with eibach/koni's and the vibrating seemed like it went away but although it isnt as bad ive begun to notice it again.
I really have no idea what it could be, so can you help me out...
Alex
Old Mar 1, 2007 | 07:44 PM
bvtran's Avatar
94c Big Max
check your ball joints -> tie rod -> rack bushing
Old Mar 1, 2007 | 08:11 PM
do you have any pics of these things, im a total noob on suspension stuff...
Old Mar 2, 2007 | 02:11 AM
bvtran's Avatar
94c Big Max
the two rack bushings and outer tie rod can be found here (courtesy of Green):
http://uploader.ws/upload/200702/tie_rod_torque.png
ball joint:
http://cgi.ebay.com/ebaymotors/Lower...spagenameZWDVW
I initially was planning on changing the rack but I came to realize it looks fine. And I'm pretty broke right now too so I returned it for full refund. My pump was the one getting bad so I have to change that. So when I work on that I would like to change the rack bushings too. Does anyone here know if I can change the 2 rack bushings without removing the rack? I know that's laziness but can I get away without taking it off?
Old Mar 2, 2007 | 08:35 AM
DanNY's Avatar
Ad·min·is·tra·tor
yes. the bushing is split.
when you do the job loosen one side...then remove the bracket on the side you want to swap bushing. same thing when you want to do the other side.
Old Mar 2, 2007 | 05:51 PM
Thanks for the links. im taking it to my autoshop on monday to have it on our lifts so my teacher and i can look at it.
Alex
D Mason
Jun 21, 2016 04:43 AM
bigfrank
Oct 1, 2015 12:51 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
