E124 diode and lighting mod
Old Mar 2, 2007 | 11:34 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
I've been looking at the FSM, and from what I can tell, applying a 12v current spliced into any part of the parking light, sidemarker, and clearance light system will inadvertantly light up everything on the whole line, no matter where I splice the current in, because there are no diodes in that system preventing backflow, whereas there are in the cornering light system (E124 on the harness). Am I right about that?
I'm doing a custom wiring job on my sidemarker/corner lights that activates on the touch of the turn signal switch, regardless if the parking/headlight switch is OFF, 1st, or 2nd. But I only want to light up one corner of the car when the switch is off, but wiring it up would make the all four corners come on, I'm afraid. I haven't tried it yet, but based on the FSM diagrams I think that's what is going to happen.
So if my hypothesis is correct... does anyone have an extra E124 from a parts car that I can buy (please leave like 4" of wire on the harness, so I can just cut my existing wiring and splice it inline with wirecaps) and have shipped? Otherwise, where can I buy two diodes with a high enough rating to use on a car lighting system? Radio shack appeared to only have small, weak diodes. I've already got the necessary relays.
Also I'm considering 2 different layouts for the system. One will put the corners on dim when combo switch is off, the other will only affect the orange sidemarker.
Old Mar 5, 2007 | 02:58 PM
heresmymind
thats interesting. I made my cornors and my blinkers alternate when i turn on my turn signal. I made custom bulb holders in the cornors. so the running lights are white LEDS. but when i turn on the turn signals the orange LEDs over power the white and alternate with my oranage LED blinkers.
Old Mar 27, 2007 | 11:46 PM
http://s164.photobucket.com/albums/u...rner%20rewire/
got my spare E124, started to wire it but ran out of wire. I'll replace those stupid yellow caps with soldered quick-disconnects as soon as i get ahold of a solderer. Anyhow, the diode works as expected so far. The resistance is OK seeing as I haven't melted anything yet, and everything is normal brightness.
Once I finish, more pics, and videos. I'm wiring it as Modified Setup #2.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
A32goldylocks
Sep 2, 2015 06:39 AM
