New front main seal and whirring sound
Old Mar 3, 2007 | 06:53 PM
mszilves's Avatar
I just had my front main oil seal replaced, and there is now a noise which sounds like a kind of metallic whirring (RPM dependent)... I'm guessing it could be either one of the tensioner pulleys (on power steering/water pump belt, or a/c belt), or could it be the water pump bearing from the belts being too tight? Anyone know the easiest/most efficient way to diagnose? Also, is there any danger in waiting until Monday to take it back to have them look at it? I don't want to blow the water pump if they put the belt on too tight.
Old Mar 3, 2007 | 07:04 PM
Greeny's Avatar
¯\(°_o)/¯
If you "had" this done at a shop,TAKE IT BACK!!
Old Mar 3, 2007 | 07:50 PM
internetautomar's Avatar
mod or sell?
if a car leaves the shop with a different problem than it went in with, they (the shop) are responsible to a: tell you about it if it is just lousy timing b: fix it if it is their fault
Old Mar 5, 2007 | 07:14 AM
crabapple's Avatar
EDIT: Nevermind. You're an m/t. Not applicable..
Old Mar 5, 2007 | 09:22 AM
92 Max's Avatar
Yes, Take it back to the shop. It will teach the high school kids working at the shop with claw hammers and pliers, how to do it correctly. Basically you should be able to press with your thumb on the largest span of the belt and with a firm pressure get it to depress, say 1/2 an inch. If one feels like a steel band and won't deflect when you do this, it's too tight. Unfortunately, if the car's making noise, it's probably too late already.
kingw323
20
Oct 21, 2015 08:36 AM
seesole
Aug 26, 2015 11:22 AM
raffivegas
Aug 23, 2015 09:54 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
follyburr
Aug 7, 2015 09:50 PM
