Seat Belt Chime/Light
Old Mar 8, 2007 | 11:12 AM
Jon94SE's Avatar
So my car is convinced the seat belts aren't connected when they are. It'll chime randomly and flash the light about every five minutes now. I read on Craig's page about the bypass trick on the sensors but that didn't work for me for whatever reason. I've heard there's a a wire you can cut on the TCU to make it go away but I'm having trouble figuring out which one with the FSM and I'd rather not just start chopping wires. Does anyone know which one it is? Thanks
Old Mar 8, 2007 | 01:12 PM
elusivemax93's Avatar
bro if the chim is annoying u and you want to get rid of it all together u can juz take out ur tach and remove the lil white chim box connected to the rear of the tach
Old Mar 8, 2007 | 02:41 PM
Sgibb's Avatar
If the write-up on craigs page didnt work you prolly didnt do it right i did both of mine 2 years ago and i havent heard the chime since
Old Mar 8, 2007 | 03:07 PM
gdmaxse's Avatar
you can remove the magnet from the clip that slides along the door and it will never chime again
you could also put a piece of electrical tape over the magnet and it shouldn't trip the sensor.
Old Mar 8, 2007 | 04:10 PM
Greeny's Avatar
¯\(°_o)/¯
My car has don the same thing intermittently for years now,i just ignore it..
Old Mar 8, 2007 | 04:59 PM
Jon94SE's Avatar
No I'd like to keep the chime because I use it for when my headlights are left on. When I did Craigs method it worked for awhile then it came back, the jumper wire probably just came out I'll try that again. And Yeah GreenMax I just ignore it as well but I have to explain it to everyone that gets in my car and I grow weary of it. They think the car is going explode.
Old Mar 8, 2007 | 05:06 PM
ozzombie13's Avatar
I will eat your children
i took my chime out a long time ago.and i have only left the lights on once. but thanks to my yellow top the car still started right up.
Old Mar 8, 2007 | 05:08 PM
Greeny's Avatar
¯\(°_o)/¯
Just tell them it's the voice activated passenger seat ejection system..
Old Mar 8, 2007 | 06:25 PM
bvtran's Avatar
94c Big Max
I hate that sound whenever it goes off, it always surprise me while I was driving.
elusivemax93 , is there a way to do the same thing to disable the airbag red light? I have no ideas why it always goes on. Everything was plugged in. I could careless for it really. I just wanna get rid of it all together along with that annoying red light.
Old Mar 8, 2007 | 06:34 PM
gdmaxse's Avatar
yes you can pull the airbag light, i pulled mine when i swapped a non airbag steering wheel in. just take off the dash and unplug it
Old Mar 8, 2007 | 06:36 PM
bvtran's Avatar
94c Big Max
which wire? how does it looks like?
Old Mar 8, 2007 | 08:27 PM
Jon94SE's Avatar
So I take it nobody knows which wire I speak of then?
Old Mar 8, 2007 | 08:55 PM
gdmaxse's Avatar
it is in the instrument cluster right behind where the airbag light displays on the dash. it looks like a small bulb with two wires coming out of it, one red and one black.
Old Mar 9, 2007 | 12:05 AM
lolz umm last i remember when i removed my chim.the backing to the bulb that has all the wires built into the instrumental cluster. and like gdmaxse said juz remove the light bulb and thats it you wont be seeing that light again. but if you have air bags in your car its maybe wish that instead you fix that problem causing the light to turn on intermitently
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
