Windshield washer fluid pump not working-electrical?
Old Mar 10, 2007 | 12:25 PM
hoyshnin's Avatar
Baby's on the Half Tip!
My wipers work fine, but the washer fluid won't spray. I looked underneath the splash guard at the bottom of the washer fluid reservoir and the pump doesn't do anything when the washer fluid lever is pulled. I do hear a clicking from the relay box (I think that's what it is) next to the battery every time the lever is pulled, though. Does this mean I have an electrical connection problem, or maybe a fried pump? Anyone ever experienced this or have any advice?
Old Mar 10, 2007 | 03:19 PM
Greeny's Avatar
¯\(°_o)/¯
My guess would be the pump is toasty-roasty..
Old Mar 10, 2007 | 05:53 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
That was the first thing I fixed on my car after I bought it. About $20 from some auto store, but beware, they rust out. Aftermarket ones are generic, and do not involve removal of the old pump. The new pump will suck the fluid through the chamber of the old pump, then send it on its way. Make the old-pump-to-new-pump line as short as possible, and mount it at or below the level of the old pump, because pumps push better than they pull, well, this one does at least.
But before you do any of that, disconnect the harness from the pump, stick a multimeter in it, turn your ignition to ACC, have a friend pull the handle while you're watching your voltage. Should be 12-14v as long as the handle is being pulled. If not, look elsewhere in the electrical system.
Old Mar 10, 2007 | 07:28 PM
internetautomar's Avatar
mod or sell?
I bought a direct fit for my old VE when it was leaking. no hacking required
Old Mar 10, 2007 | 07:47 PM
would there be any difference between VG and VE washer pump/tanks? seems like too small a detail to have been made differently. I wish I'd been able to find a direct-fit pump but that was before I started going to junkyards or joined the Org or anything.
To the poster: http://forums.maxima.org/showthread.php?t=474118 ask him if he's got one you can buy, if you test and your voltage is good
Old Mar 11, 2007 | 12:10 AM
maximagician's Avatar
[QUOTE=capedcadaver]would there be any difference between VG and VE washer pump/tanks? seems like too small a detail to have been made differently.
ve washer pumps have...oh , lets say....30 more hp
Old Mar 11, 2007 | 05:15 PM
[QUOTE=maximagician]
I'll believe it when I see it.
Old Mar 12, 2007 | 06:25 AM
hoyshnin's Avatar
Yeah, I'll have to get a multimeter (don't have one right now) and check, I figured if it was a really common problem maybe I could just assume it was the pump, but I'll have to check the voltage.
Old Mar 12, 2007 | 07:15 AM
$7 dollar bin at Harbor Freight! By a spare if you plan to use it alot, in case the battery on the first dies in the middle of a testing job.
Old Mar 12, 2007 | 07:29 AM
polarb68111's Avatar
Reppin Nebraska by myself
30 hp sounds about right!!
Miket2006
Mar 1, 2021 03:55 AM
Need help
23
Oct 2, 2015 08:56 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
