What's wrong with tail lights?
Old Apr 8, 2007 | 02:15 PM
Suya's Avatar
I noticed that my tail lights are not working when I turn on head lights. If I apply breaks, only right side light is working. Turning single lights are working fine.
I checked the bulbs. They are fine. I pulled a fuse that is under steering wheel (I looked at the index, it says 15A is back light), it seems fine. Any idea what's wrong? Thanks.
Old Apr 8, 2007 | 02:35 PM
Kountz430's Avatar
bald aggression est 78
trace your wiring you might have a break in one or two its a pain in the *** though but give it shot make sure to clean all connection and check your grounds
Old Apr 8, 2007 | 02:39 PM
xx-Marshall-xx's Avatar
kthxbye2u
relays?... check the wiring harness?
Old Apr 8, 2007 | 02:43 PM
Greeny's Avatar
¯\(°_o)/¯
Check the rear bulb sockets for corrosion...
Old Apr 8, 2007 | 04:19 PM
Tquick's Avatar
Test your fuse with a tester. They can look good, and still be bad. Check for relays, not sure if there are any involved with the tail lights. If that checks out, check sockets for corrosion, make sure ground connections are clean and tight, and test wiring at sockets for power. If you don't have power at the sockets, start tracing the wires back toward the front of the car, testing every so often to see if there is juice.
Old Apr 10, 2007 | 02:08 PM
«§»Craig B«§»'s Avatar
very likely that it's your tail light sockets like greenmax and tquick said. It's a pretty common problem on these cars. Search for more details
Old Apr 12, 2007 | 12:07 AM
gfnk357's Avatar
I had the same problem with an old vw rabbit, I checked all the wiring and it turned out to be a bad ground in the harness.
mvm062
Nov 30, 2020 09:00 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
A32goldylocks
Sep 2, 2015 06:39 AM
