View Poll Results: do you have a stuck antenna
Yes
45.61%
No
45.61%
Not sure if i have an antenna.
8.77%
Voters: 171. You may not vote on this poll
do you have a stuck antenna?
Old Apr 16, 2007 | 10:07 AM
  #41
Badman_Maxima's Avatar
Yeah mine seized and stayed down.... so i took it all off and used an aftermarket one.
Old Apr 18, 2007 | 10:25 PM
  #42
gfnk357's Avatar
Mine was stuck for years, I finally went on ebay, spent $18, got a new mast and had it working again after 20 minutes of work.
Old Apr 19, 2007 | 08:31 PM
  #43
Parthur's Avatar
Not sure about antena
Hello guys I am new here, I just got a Max SE 00, and I am not sure if it has antena?? is it internal??
Old Apr 19, 2007 | 09:11 PM
  #44
ColombianMax's Avatar
Hey if I'm not mistaken I believe you might be in the wrong forum as you have a 2000 and you're in the 1989-1994 section.
Try hitting going to forum.maxima.org and hit 5th Generation 2000-2003
Old Apr 20, 2007 | 08:10 PM
  #45
bigmax90's Avatar
yeah, unplugged mine years ago. The cable breaks up inside and it always happens again . good luck
Old Apr 21, 2007 | 12:09 AM
  #46
x91max
i went to a you pull it junkyard, and cut another antenna out of an old oldsmobile. bought a rubber washer from a hardware store and made it fit snugg. works better than the original nissan one did.
Old Apr 30, 2007 | 07:02 AM
  #47
Michael's Avatar
Back in a 3rd Gen.
I still say this is the way to go:
that and a powered internal window antenna.
Old Apr 30, 2007 | 07:05 AM
  #48
Greeny's Avatar
¯\(°_o)/¯
Agreed..Looks nice..
Old May 8, 2007 | 01:26 PM
  #49
sta's Avatar
sta
Originally Posted by Mikxima
My antenna goes up and down all the way, but once it reaches the top, the motor that drives it continues to crank away on it. I don't even know how long it lasts, because I'm usually driving and forget about it.
Same here :\
The atenna in my moms 97 4runner doesnt work though, the motor runs but the atenna dont go tho...
the atenna is kinda like the maxima's so i figured i'ld ask
Old May 8, 2007 | 02:33 PM
  #50
Quickywd01's Avatar
Mine goes up about 4 inches and stops. But I can pull it out all the way and it's all crusty. I'll try to clean it like someone suggested and see what happens. But it's good to know I can buy a new one for $20.
Old May 8, 2007 | 04:54 PM
  #51
Maxima Man's Avatar
Well get this mine stoped working while my parents owned the car and I replaced it with a aftermarket powered antenna and one cold wet morning the antennas gears froze up or became brittle and when my dad went to start the car the antenna spun and spun till all its gears were toast
So I was mad with my dad because the antenna was only probably 3 weeks old!!
Now I have a manual antenna and I just recently backed out of our garage to fast when the door was still going up and I bent the mast forward!
So I just got out mad and spun it around to slant backward and called it a day!
Old May 8, 2007 | 05:50 PM
  #52
Quickywd01's Avatar
lmao
Old May 8, 2007 | 08:02 PM
  #53
CapedCadaver's Avatar
Call me Wookiee Goldberg
mine too. the top 2 sections pull out and the thing up the center rod is broken in at least one place.
Old May 9, 2007 | 09:44 PM
  #54
Maxpwer's Avatar
No turbo, no care!
http://mandysbabies.com/93sale/noantenna.jpg
Well Ive had satellite radio for 4 years now, and probably havent listen to FM in about that long. I want to remove my external antenna but Im paranoid of some type of emergency in my area that might only be broadcast on FM. What type of internal antenna did you use?
Old May 10, 2007 | 02:16 PM
  #55
Michael's Avatar
Back in a 3rd Gen.
I used a powered antenna from carquest. It has sticky tape that you mount it to the window with. Its very small and hardly seen if you don't know what you are looking for.
It picks up much better than the factory antenna as well.
Old May 14, 2007 | 02:07 PM
  #56
Quickywd01's Avatar
Can you post a link to it? Or if you have a part number. Do you remember how much it cost?
Old May 14, 2007 | 02:24 PM
  #57
Michael's Avatar
Back in a 3rd Gen.
no I cant. No I don't. Go by your local carquest, look in their catalog under antennas and its the only one that is powered and window mount. I think I got it for $25 or so but I get a pretty good discount there. I think it probably retails for $35-$40. If I run across my carquest catalog I will get the part number but I haven't seen that thing in a while.
tarun900
19
Dec 20, 2021 06:57 PM
chisam14
Nov 6, 2018 08:56 PM
05RLS2
Apr 14, 2016 11:49 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
