Just Talked With a "Tranny Guy"
Seems like he knows his stuff...Had his own shop for part of the 18 years he worked around Grand Rapids...Said he has worked on pretty much everything foreign and domestic. Lives way out in No-Man's-Land now and works out of his barn. Also said the humming noise coming from my tranny is just a bearing starting to get worn.
Anyway, I was talking to him about the differences between a non-VLSD model like mine and the VLSD model. He said that he could turn my VG-5 into a limited slip unit. Is there any merit to this statement?
Of course I want a VE VLSD tranny...but if / when my tranny goes, this guy is down the road a few miles...waiting on a quote from him...anyway, as things currently sit, I could buy a used VE tranny ($400 shipped) and put it in an see how far that takes me...We'll see how this guys rebuild price compares to that $400...The current tranny is staying right where it is until it doesn't go no mo'...
I've done close to all the mods I reallly want to on this car, time to start focusing on my game plan for acquiring a Goat...
The VG and VQ trannies use the same open diff.
the quaife is designed around the 4 gen open diff.
According to the other guys in the SC/turbo forum, the VG, VE, and VQ-5 guts are all the same but I don't believe that.
nonetheless, the VG should be able to fit a quaife diff.
Originally Posted by maxitech
from this point will it go down hill quicky or take awhile? it still shifts and acts fine, so I'll keep driving it for now. When it does fail, will it progressively get worse as mentioned above, or will it catostrophically fail?
I'm still wondering if your whining sound is the front bearing though. Maybe make an audio or video file while driving.
exactly what he said. the problem will slowly cause other issues to happen.
mine was simply a 1,2,5,r lockout. so I only had 3&4 sometimes. once I'd get rolling, then I could shift back into 1-5+r, but often I would be forced to start off from a light in 3rd gear in heavy traffic. get rolling about 5mph, then the fluid would move the bits around and I could downshift again and get outta there.
It also got to the point it was causing enough shaft wobble to ruin the seal on the input shaft and i had royal purple75w90 literally RUNNING into the bellhousing while the car was running. I was at a track event and got black flagged because they could see the oil dripping out and hitting my exhaust, causing smoke behind the car.
when I pulled into the pits, I had a 4" puddle (not a small spot that seeped to 4", but a real puddle) of fluid every time I shut off the car.
I drove it home thursday night, pulled it apart on friday morning, rebuilt the tranny, and had it running friday evening. I was back at the track for another 2 day event on Sat & sun. no drips, no smoke.
Originally Posted by Hectic
If the whine is in fact your input shaft bearing going out, you'll eventually start hearing the ***** smacking together instead of the sound you're hearing now. I put around 10k miles on my car before I got around to fixing it. I was finally forced into doing it, but it wasn't becuase of a "catostrophic" failure. Eventually, bits and pieces of the broken cage were loose and kept shorting out the position switch in turn blowing the engine control fuse every time I moved the shifter. Around that time, it would also get locked out of 1-2 and make loud grinding sounds when letting off the clutch a lot of the time. It's definitely possible to cause more problems than that though, I think it was mtcookson who told me he busted off parts of the case by not changing it out when he had the chance. So if it progresses, plan on replacing the bearing this summer.
Zach
I am still gonna wait to hear back on a rebuild price from te guy, but I'm pretty sure I will buy a used VE unit in the near future. That way I can throw it in the trunk for Maxus, so if my tranny fails at any point during the event I'll have you guys there to help me swap it...LOL!
Seriously tho, I will probably try to have it swapped out before Maxus and maybe I can unload my current tranny for 100 bucks or so...
why has no one tryed this
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
@ thread title...
