Input Shaft Bearing
Old Apr 21, 2007 | 10:02 AM
x91max
Input Shaft Bearing
Has anyone ever attempted to replace the inputshaft bearing. i get the bearing on tuesday but i would like to know what im up against. also im getting a kind of ticking noise from the transmission at an idle with the clutch out. when i press it in all the way it goes away. when i accelerate the ticking accells and gets louder. is this the isb?
Old Apr 21, 2007 | 10:44 AM
goon9's Avatar
ticking? Or marble rolling drone?
ISB bearing isn't the hardest thing, if you can open a tranny and put it all back together.
Old Apr 21, 2007 | 10:45 AM
x91max
marble rolling drone, howd u come up with that i couldnt seem to explain it.
Old Apr 21, 2007 | 10:49 AM
Jeff583's Avatar
probly isb, it stops when u push in the clutch because the input shaft stops spining, how many miles? If you could cofidently replace the clutch yourself, you should easily be able to take on a isb job. You should be able to find other threads about this, try takin a look at some of them for more info and input.
Old Apr 21, 2007 | 10:54 AM
goon9's Avatar
It's not as easy nearly as a clutch... Have you every changed one a isb bearing?
Consider if you F it up, then your screwed.
DO not go into without an fsm. There's what 10-15 steps in just opening the case.
Old Apr 21, 2007 | 10:56 AM
Jeff583's Avatar
That is actually basically what it is, steel marbles or ***** inside of a steel casing. They start to make this noise when the get worn out and sloppy inside of the case and will adventualy come apart into many peices, thats what happened to mine.
Old Apr 21, 2007 | 11:00 AM
Jeff583's Avatar
I have actually done two of them, my first one i replaced all of the bearings and a few other things. If it is only the one isb then it is not very difficult as long as you take your time and use common sense, and yes i do agree a FSM is a very good idea for your first time.
Old Apr 21, 2007 | 11:45 AM
x91max
does it require a press?
Old Apr 21, 2007 | 12:42 PM
goon9's Avatar
To do it properly yes. But I dremeld mine off and carefully tapped the new one in with a punch.
Old Apr 23, 2007 | 07:02 PM
x91max
does this car require you to split the transmission case? or can u just unbolt a retainer and pull the shaft out?
Old Apr 23, 2007 | 08:09 PM
Jeff583's Avatar
You split the case.
When i did them i had winter on my side and put the shafts out in the snow for awhile then brought them in and heated the bearing and took them off with ease, put them on the same way, worked great.
Old Apr 23, 2007 | 08:20 PM
x91max
shafts? more than one?
Old Apr 23, 2007 | 08:40 PM
Jeff583's Avatar
You will only need to replace the INPUT SHAFT bearing, i replace all of the bearings in the transmisson so therefore it was shafts for me.
Old Apr 23, 2007 | 10:31 PM
x91max
how hard is this going to be... i dont got a press but i could cut it off with a dremel. and tap it on. and will the other shafts hold there own in there with the case split.
Old Apr 24, 2007 | 06:37 AM
Jeff583's Avatar
dont worry about the other bearings at all, only focus on the isb, to put the new bearing on try putting the bearing in the oven for awhile then see if it will go on any easier.
Also be VERY careful with the dremel, i have not done this but goon says he has so any ?'s ask him.
Old Apr 24, 2007 | 07:27 AM
goon9's Avatar
You can't shange the other bearings without a press.
If your not comfortable doing it. Pay somone to do it right.
Old Apr 24, 2007 | 09:09 AM
Jeff583's Avatar
Acutally you can change the others without a press, just how i mentioned above. By heating the bearings and cooling the shaft.
Old Apr 24, 2007 | 01:57 PM
goon9's Avatar
gotcha, never did try that method. Though... I don't have any snow here either.
Old Apr 24, 2007 | 03:25 PM
akurtzer57's Avatar
Heres some helpful pics
Here are some pics of what you are going to get into just make sure you keep everything clean and lay it out nicely so you won't lose parts or forget to put it back in. I pulled the tranny and had all the gears brought down to machine shop to get the new bearings pressed on if they don't come with new races I would recomend it.
http://www.cardomain.com/member_page...04_70_full.jpg
http://www.cardomain.com/member_page...04_72_full.jpg
http://www.cardomain.com/member_page...04_71_full.jpg
Old Apr 24, 2007 | 09:15 PM
x91max
wait so dont get em pressed on if they dont have races?
Old Apr 25, 2007 | 06:10 PM
goon9's Avatar
Go read your FSM.
Old Apr 26, 2007 | 01:03 AM
x91max
those fsms only go as low as a 94, and i looked at it and it doesnt even look simular.
Old Apr 26, 2007 | 04:07 AM
goon9's Avatar
The cases and everything are the same.
I'm done helping you.
Old Apr 26, 2007 | 10:53 AM
Jon94SE's Avatar
As you can see we were a little un-organized with mine but we got it done and a year later it still works. Wasn't really too tough though...
Old Apr 26, 2007 | 10:56 AM
Greeny's Avatar
¯\(°_o)/¯
Dude,the green shoes..
Old Apr 26, 2007 | 11:46 AM
internetautomar's Avatar
mod or sell?
my thoughts too
Old Apr 26, 2007 | 02:03 PM
goon9's Avatar
They came with the pick
I was thinking Pink Towel.
Old Apr 27, 2007 | 10:06 PM
x91max
alright i replaced the bearing and put it all back together and runs great altho i didnt put one shim on the input shaft bearing. i couldnt get it to stay and i didnt want it to fall out in there so .
litch
123
Jan 4, 2024 07:01 PM
gigabyte
Jan 6, 2017 06:05 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
Andy29
Sep 29, 2015 05:32 AM
