Engine Oil
Old Jul 19, 2007 | 09:34 AM
maxima_man1992's Avatar
Engine Oil
What type of engine oil do you guys recomend. I was thinkin about goin with Royal Purple but that seems a little to pricey. How many quarts does the VG take?
Old Jul 19, 2007 | 09:41 AM
Pearl93VE's Avatar
I can has?
The FSM states 4-1/8 US qt. (With Oil Filter) 3-3/4 US qt. (Without Oil Filter)
You Be the judge, I always went with 10W-30 full synth in both my cars. But it RARELY ever goes below 20 degree's or so here in Florida.
Old Jul 19, 2007 | 10:20 AM
DizZL3's Avatar
Quarts
I use 10w-30 synthetic also being i work at firestone, i just sneak it in my car . I put 4 quarts in it and its usually at the line for me on my VG.
Old Jul 19, 2007 | 11:11 AM
Greeny's Avatar
¯\(°_o)/¯
Castrol 5W-30 fO LiFe!!!
Old Jul 19, 2007 | 11:21 AM
maxitech's Avatar
Castrol GTX 10W-30 right now for the summer months, 5W-30 any other time...The way I see it, the VG is an old-school motor, so it's not really necessary to run expensive synthetic. Once I pick up something more modern and powerful (probably a GTO), I will most likely run Royal Purple.
Old Jul 19, 2007 | 11:28 AM
internetautomar's Avatar
mod or sell?
whatever 5w30 is cheap for the top off. for oil changes usually pennzoil/shell.
nowadays though it's just whatever is handy (No VE, No worries)
Old Jul 19, 2007 | 11:39 AM
maxitech's Avatar
I've heard bad things about Pennzoil, as well as Quakerstate...inferior oil FTL
Old Jul 19, 2007 | 01:51 PM
mod or sell?
on time oil changes FTW
Old Jul 19, 2007 | 03:59 PM
CyMax's Avatar
Just about any High Mileage oil, 10-30 summer 5-30 rest of the time here. Only Yota filters.
Old Jul 19, 2007 | 04:15 PM
93SCMax's Avatar
98 SE
4 quarts of Havoline or Valvoline 10W30 here in South Carolina. Always changed every 3000 miles with a Fram or Nissan OEM filter. No need to run synthetic oil on an engine/car this old although I do run synthetic oil (Mobil1 5W30 or 10W30) in all my other newer cars/trucks.
I don't think you need to spend the $ on Royal Purple...but you make the call. If your engine has gasket leaks and is dripping oil, Royal Purple would be a waste.
Old Jul 19, 2007 | 06:16 PM
Cliff Clavin's Avatar
Way out West
I use 5w30 because it gets pretty cold here.
I normally use Mobil 1 because it's cheap at Costco, but I the last time I changed it, I didn't really want to go 100 miles to Costco, so I just bought the NAPA synthetic, which I think is made by Valvoline. I also use the Toyota filter on mine, since it's a VE.
Old Jul 19, 2007 | 08:32 PM
Liquidnails's Avatar
I run 10w30 in the summer and 5w30 starting september. I buy whatever is on sale and change every 4000-5000km. I've tried the high mileage stuff, and I really can't say if i's worth the extra $ or not.
Old Jul 20, 2007 | 02:30 AM
Tampamaximus's Avatar
10w30 Castrol syntec
Old Jul 20, 2007 | 03:06 AM
Hectic's Avatar
I usually buy a case of whatever's on sale. Got a 6 pack of Pennzoil platinum synthetic for about $12 last time with a rebate. The casheir deducted the amount of the rebate at the register, so I didn't have to bother sending it in I fill my vg with 3 1/2 quarts, and top it off a couple times between changes. Royal purple is spendy, money better spent elsewhere imo.
Old Jul 20, 2007 | 09:23 PM
Quickywd01's Avatar
I just put in some castrol high mileage. It's pricey but when it's on sale for half price I'm going to grab a case otherwise castrol gtx 5w-30 should be good. I also read that the vg takes 4 and 1/8th but when I went to fill it I found 4 to be more than enough.
Old Jul 21, 2007 | 09:19 AM
nForce's Avatar
The Computer Guy
5w30 Quaker State Peak Performance
Helps maintain engine life
Quaker State Peak Performance is fine-tuned for vehicles in their prime. It helps maintain engine life with:
• Resistance to thermal breakdown
• Protection against harmful deposits
• Security in changing climates and temperatures
• Resistance to oil thickening and consumption
• Control of oxidation
The result:
A clean-running and long-lasting engine.
Quaker State guarantees your engine with a 10-year/250,000 mile limited warranty, even if you change your own oil.
Only oil I have used on the maxima for past 5 years still runs great. Plus its only 8.65 for 1 gal container at Walmart
Old Jul 23, 2007 | 09:38 PM
nForce's Avatar
The Computer Guy
Been using Quakerstate Peak Performance for past 5 years and man was the internals on my engine clean (when I replaced valve cover gasket)
Old Jul 27, 2007 | 07:13 PM
Kountz430's Avatar
bald aggression est 78
i use penzoil high mileage.i switching over to synthetic blend( my own blend) imho i dont how much of these so called synthetic blends are truly synthetic blends it could be 20 percent snythetic and 80 percent crude oil and vice verse.so i make my own i changed my wifes oil and put two quarts of regular and two quarts of full synthetic since it only takes 4qts. My car is'nt do for an oil change yet. but i have no problem with penzoil its alright with me
Old Jul 27, 2007 | 09:34 PM
ColombianMax's Avatar
Redundant thread but here goes:
Castrol GTX 10w-30 Summer
Castrol GTX 5w-30 Winter
If engine ever gets rebuilt, its Mobile 1 10w-30 ALL THE WAY
Old Jul 27, 2007 | 09:54 PM
Tom's Avatar
Tom
I use Pennzoil 10W-30. I've always heard rumors about Pennzoil not being good, but I owned my car for over 10 years now and that's the only oil I used and the car does not burn any oil.
Old Jul 27, 2007 | 10:19 PM
nForce's Avatar
The Computer Guy
Does anyone use Quaker State or am I the only one? Just curious
Old Jul 28, 2007 | 05:37 PM
elusivemax93's Avatar
Mobil 1 full synthetic 5w30 with K& N oil filter. Fram oil filters on Ve's have been said to do bad things. When i first bought my car the guy before me was using fram so i right away did an oil change and put on a K & N oil filter.
kjlouis
Oct 3, 2015 05:29 AM
97_GXE
Sep 15, 2015 06:47 AM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
ag90fox
Sep 9, 2015 12:22 PM
