Nos on automatics???
Old Aug 7, 2001 | 01:06 AM
khrfadz's Avatar
my 94 gxe has like 66k miles on it and the engine is in perfect condition. since the mileage is low i was thinking bout nos but realized my car is an automatic. can nos be used on automatics or only for manual cars???
Old Aug 7, 2001 | 04:41 AM
92ZexMaximaSE's Avatar
Gee, I hope so cause I've had mine on my 92 SE (auto) for over a year now. Oh yeah, my car has over 130,000 miles on it.
Old Aug 7, 2001 | 06:00 AM
CandiMan's Avatar
Say Candyman 5 times
Since forced induction not available without custom work I've been thinking about nitrous as a replacement. I have a auto like yourself, but with a VB upgrade and over 100K miles.
Did you do anything to prep your engine before the ZEX system. Colder plugs, retarded ignition, upgraded fuel pump, etc. Or did you just plug and play, how much increase are you running
Old Aug 7, 2001 | 06:39 AM
Cincy94Max's Avatar
This reminds me of a question I had concerning NOS. I read on their website that NOS should be used above 2500 RPM for best results. Assuming that I shift my automatic manually at around 5500-6000 RPM, and assuming that I use NOS from 3000-5000 RPM, wouldn't the only wear and tear my transmission would feel be on the torque converter? Since I wouldn't be making the transmission shift while I was on NOS, the transmission itself wouldn't feel too much wear and tear. Am I right in these observations or completely off track?
Old Aug 7, 2001 | 07:16 AM
[QUOTE]Originally posted by CandiMan
[QUOTE]Gee, I hope so cause I've had mine on my 92 SE (auto) for over a year now. Oh yeah, my car has over 130,000 miles on it.
Actually no.. I did research a lot on getting a new fuel pump, ignition, plugs etc.. The only thing I did change was getting the Zex plugs which were specifically made for Nitrous use and getting the purge valve cuz they told me it would give you a clean shot and bleed out any moisture/stale NOS. I had planned on getting a new fuel pump but that was before I had to replace my exhaust stud bolts, heater hose, and get a new dash for my broken odometer. Ugghh.. Can I have some sympathy here..
P.S. I also plan on getting the VB upgrade when I finally save up some cash..
Old Aug 7, 2001 | 01:36 PM
khrfadz's Avatar
how many shot nos u running??
Old Aug 7, 2001 | 02:02 PM
whitymax's Avatar
damn i want nitrous
what is the cheapest kit that will work well with my 93 gxe?? anyone have a clue?? nitrous express or zex. NOS is to damn expensive. any other companies??? thanks
Patrick
PS can i just install nitrous on a stock maxima??
Old Aug 7, 2001 | 02:09 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: damn i want nitrous
Zex seems to be the most inexpensive, but JCwhitney had NOS kits on sale for $375 just last month! check impactparts.com, I think they are having a sale on Zex kits. if you have an auto I would suggest you get you transmisison valvebody upgraded, it will help preserve your trans with all the extra power added by the nitrous.
Patrick
Old Aug 7, 2001 | 04:11 PM
Jon91SE's Avatar
Pusssseeeehhhh
Traaaaaannnnnyyyy cooooooooler........
Old Aug 7, 2001 | 05:04 PM
Zex comes with 3 nozzles for 55, 65 or 75 shot respectively.. I usually stick with the 65..
Old Aug 7, 2001 | 05:08 PM
Re: Re: damn i want nitrous
On the flip side, the most expensive kit I have seen is the Venom kit which I originally had planned to get before I saw the price.. they wanted over 1 grand for that bad boy.. But from what I heard it's the best NOS kit you can get. Edlebrock also has some NOS kits for Maximas.
Old Aug 7, 2001 | 11:16 PM
MaximaSE91
Best nos kit for maximas
winner is jim wolf 1200.00 Ecu controlled nitrous upgraded ecu custom nitrous plugin module visit his website for info
my cost is 900.00 for the kit im definently lookin at it the turbo seems coo to but im not a high roller!,
take it easy
Old Aug 13, 2001 | 01:47 AM
slacky
Re: Re: Re: damn i want nitrous
160,000 miles is really pushing it for 55 shot system huh? also if anybody has the little plastic insert for the automatic shifter (park, nuetral, reverse, drive,etc..) send em some mail if u got one!!!! thanx
Old Aug 13, 2001 | 05:17 PM
94SUPERMAX's Avatar
Gime some numbers.
Can anyone tell me how much more power nitrous gives a 3rd gen GXE.
Old Aug 13, 2001 | 05:21 PM
DA-MAX's Avatar
Depends what "shot" you use
25 shot= 25 hp........65 shot= 65hp and so on. since you're an auto a 50 shot "should" be safe and quite effective! should put you into the 14's(I think)
Old Aug 13, 2001 | 06:07 PM
94SUPERMAX's Avatar
Re: Depends what "shot" you use
Thanx for the info
Old Aug 13, 2001 | 09:33 PM
JRicker24's Avatar
MaximaSE91...what size rims u got, and how much of a drop??
Jeff
jefflinds_24@yahoo.com
Old Aug 13, 2001 | 11:17 PM
MaximaSE91
18in tantrums 225/40zr18 yoko paradas
1.5in drop in rear 2.5 in drop in front suspension techniques springs, cut one coil on each front spring didnt like the little bit of fender gap, so i made it so i have none
MaxStock
Dec 5, 2016 05:19 PM
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
2kmaximel
Sep 16, 2015 03:19 PM
