Why is my VE so slow??
Old Aug 26, 2001 | 05:48 PM
Jason92SE's Avatar
Hello to everyone,
I have just bought a 92se/ five speed. I have checked the motor out it is in good shape, I checked the compression, looked a the plugs, checked all of the hoses, every thing seems fine. Well I went to the track and was thinking I would get something like 15.4-15.7's and all I hit was 16.4's@84mph, that is what a stock GXE should run not a SE. And yes it does have the VE30DE motor. I'm not new to drag racing, I have taken 280zx's in to 14's with very little mods. The way I see it is I must be down about ~30HP. And does not really seem possible because the car runs so smooth.
Jason
Old Aug 26, 2001 | 06:03 PM
Sonic's Avatar
Exhaust leak perhaps? Old plug wires, slipping clutch. intake problems, bad MAFS, knock sensor, or a host of other things.
Old Aug 26, 2001 | 07:13 PM
Stealth TT's Avatar
so sowwie
Im sorry do you want me to tow ur car with my TT?
Old Aug 26, 2001 | 08:10 PM
93 SE's Avatar
anyway ,the ve suffers in heat ,not really a quick launcher unless the engine is cold ..imo
Old Aug 26, 2001 | 08:36 PM
Nismo87SE's Avatar
A couple questions?
What were your 60ft, 1/8 mile ET/traps, what was the temp/humidity and the elevation? Did you hot lap the car or allow cool down periods? Where were you shifting and did you finish the 1/4 in 3rd or 4th gear? My suggestion is to run 91+ octane and bump the base timing to 19*BTDC, clean your throttle body and do a tune up.
Originally posted by Jason92SE
Hello to everyone,
Jason
Old Aug 27, 2001 | 03:19 PM
Jason92SE's Avatar
Re: A couple questions?
My best 60' was 2.360
best 1/8 was 10.643
best et/ was 16.432/ best trap was 84.54
Both hot laps and not, no change
Right at Redline
3rd gear finish
93 octane/ with rac gas 110
timing set to stock? with this type of engine where do I adjust the timing?
Thanks for the tips I will remove the intake and clean out the throttle body. Do you think it might be a cloged cat converter?
Thanks for those that are trying to help!And to "stealth TT" thanks for the help *******!!!
Old Aug 28, 2001 | 12:20 PM
dmontzsta's Avatar
Ford Only.
It could be a ton of things.When my cat was clogged my car was very sluggish and it would occasionally stall out.But a stock VE 5 speed should hit atleast 15.6 czar runs 14.8 with just a pop charger and advanced timing.
Old Sep 2, 2001 | 02:17 AM
ThurzNite's Avatar
Re: Re: A couple questions?
best 1/8 was 10.643
Right at Redline
3rd gear finish
Man, I'm getting really worried...I'm looking to buy a 93 SE 5sp that I test drove today...but I'm seeing some really sad 1/4 times being posted. It's scaring me cuz I ran my gf's 93 Altima GXE 5sp stock 16.3@83, and that's with mad wheel hop all through 1st. I'm losing confidence in VE's....
Jay
Old Sep 2, 2001 | 07:16 AM
nubiannupe's Avatar
OG Maxima.org Member
Now I've got some stuff to look into, considering my VE runs like "ca-ca"!!
Old Sep 2, 2001 | 05:49 PM
JonnyMax's Avatar
Heres some not so sad times for you
And Im sure Czar will have some even better ones soon.
Melissa40
Jun 30, 2017 10:04 AM
D Mason
Jun 21, 2016 04:43 AM
Andy29
Sep 29, 2015 05:32 AM
keensali
Sep 23, 2015 08:59 PM
Bonka
Sep 14, 2015 11:18 PM
