clock fix and MAF testing...
Old Sep 20, 2001 | 06:35 AM
«§»Craig B«§»'s Avatar
added a new how-to on my site to fix clock
link in my sig
also, many have been talking about checking their MAF (mass air flow sensor) recently so here is the procedure to test it:
taken from FSM:
The Mass Air Flow (MAF) sensor directly measures the amount of air flowing into the engine. The sensor is mounted between the air cleaner assembly and the air cleaner outlet tube.
The sensor utilizes a hot wire sensing element to measure the amount of air entering the engine. The sensor does this by sending a signal, generated by the sensor when the incoming air cools the hot wire, to the ECM. The signal is used by the ECM to calculate the injector pulse width, which controls the air/fuel ratio in the engine.
Testing
1. Using a multimeter, check for voltage by backprobing the MAF sensor connector. Connect the + probe on the tester to the B terminal of the connector. This connector should have 5 wires going into the 6 slot connector. The lettering starts on the side where the first wire is (A, B, C, D, E, empty). So you want to test the second wire on the side without the empty connection. Keep this connector connected while you are running the tests. Do this by folding back the rubber boot from the back of the connector
2. With the ignition switch ON and the engine stopped, voltage should be less than 1.0 volt.
3. With the engine idling at operating temperature, voltage should be 1.0-1.7 volts.
4. With the engine running at approximately 2,500 rpm, voltage should be 1.5-2.1 volts.
It is important to watch for a linear voltage rise in response to increases in engine rpm, up to about 4000 rpm.
5. If voltage is not within specifications, check the power and ground circuits.
6. If the power and ground circuits test okay, the MAF sensor may be faulty.
Old Nov 18, 2003 | 01:30 PM
chris92's Avatar
link in my sig
taken from FSM:
Testing
Craig,
I have a VG, will this procedure work?
Old Nov 18, 2003 | 01:36 PM
Pervis Anathema's Avatar
Originally Posted by chris92
Craig,
Yes, the VE and VG use the same part.
maxinmaxima's Avatar
Man, you're helpfulness never ceases to amaze me. Thanks on behalf of everyone with a 3rd gen who has ever used your site/advice.
Thanks!!
Old Nov 18, 2003 | 02:30 PM
-shock211-'s Avatar
thanks craig!
just what i was looking for.
Old Nov 18, 2003 | 03:26 PM
crazy4maxima's Avatar
http://www.geocities.com/bracecraig/maxima/links.html
not working in the link]
Old Nov 18, 2003 | 04:01 PM
Originally Posted by crazy4maxima
what?
this thread is over 2 years old, good searching chris
Old Nov 18, 2003 | 04:33 PM
lol the link that i posted up to your web site is down... damn it i got owned by old postes
Old Nov 18, 2003 | 05:43 PM
that link works fine for me
Old Nov 18, 2003 | 08:08 PM
subs1000w's Avatar
i was also confused because i used the site to fix my clock over 1 year ago
Old Nov 19, 2003 | 11:19 PM
nubiannupe's Avatar
OG Maxima.org Member
Once again... bring out the dead (posts)! Still, good info, though.
TallTom
57
Oct 14, 2025 05:16 PM
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
