My gas mileage sucks
Re: My gas mileage sucks
Originally posted by Laly
any thing i can do to help get better gas mileage. i kind of drive hard sometimes, but i know i should be getting more than 16-18 miles per gallon.
-tire pressure. Especially on aftermarket rims/tires
-spark plugs. Gotta get enough spark for optimal combustion
-spark plug wires. Gotta get the spark to the plugs!
-air filter. Your engine needs to breathe. K&N all the way, I recommend the drop in despite what anyone else will tell you (especially Jiffy Lube!)
-ignition timing. You may need help with this one, and it requires special tools (timing gun, etc.)
-timing belt. They loosen up when they get old.
-intake and throttle body. Sometimes dirt can get in these and cause bad flow. Again, based on your experience you may need help.
If I can think of anything else I will post it. These should give you a good start though, and there are some really knowledgable and experienced people on these boards that can also help. Good luck!
Originally posted by Kashoggio
try your fuel filter, it sometimes helps. Also the brand of gas is a thing too, Getty gas sucks
my MPG sucks too
my auto 92 SE...99K miles....i always put super 93 octane gas in....i get only 13-15 mpg (heh original sticker says 20-26).....i drive mainly to/from school and to/from work which is moderate stop and go but i mean cmon i think the 13-15 is WAY too low; i basically use 3/4 tank a week (18 gal tank)
Re: my MPG sucks too
You are however taking the # of miles driven and dividing them by the # of gals to top off the tank right? If not that is like doing a 0-60 and stopping the clock at 55mph
LOL.
![Roll Eyes (Sarcastic)](https://maxima.org/forums/images/smilies/rolleyes.gif)
Re: Re: my MPG sucks too
Re: Re: Re: my MPG sucks too
There are a couple of things to check. Make sure your EGR valve is working properly and if possible remove the control valve and clean it. Replace your fuel filter with a 90-95 300zx unit #FF651 at autozone. Clean your throttle body/intake collector that should help. Check your o2 sensor as described in the FSM. But if you do mostly stop and go driving that is the best you are going to do.
yes that is what i do...
yeah but im gonna do a little troubleshooting on it...for a week me and my dad will switch cars after the holiday break (he does mainly highway to work and i do alot of stop and go to school); so well see how that works
06-06-2017 02:01 PM
