Why do I keep hearing about advancing timing??
Old Oct 9, 2001 | 08:40 PM
AKAICEBERG's Avatar
Hello, I dunno what it is but lately all I read is y/i/ADVANCED TIMING. I know that advancing the timing will give the vg a little extra power, but all this talk makes me think I'm missing out on something big!! I'm gonna be advancing my timing soon, so I will find out what all the rave is about soon enough.
Will timing advance be faster than a stock vg with the same modds?? Where did you notice the most gains from the advance?? What is the highest advance can I go(18-20)??
Thanks a lot,
Kevin
Old Oct 9, 2001 | 10:46 PM
ghostmax's Avatar
Well it's gonna be my next mod since I want to save my money. From what I've been reading it mostly adds low-end. People set it around 20 degrees. You should probably use a timing light just to be sure although I think some have just moved it w/o one. Here's a link:
http://members.csinet.net/tisch/maxima/
Old Oct 9, 2001 | 10:55 PM
SkyMax's Avatar
When you advance your timing make sure you are using gas thats 89 octane or better. I suggest you use 92 octane or better but other people use 89 octane and say they have no problems.
Old Oct 9, 2001 | 10:59 PM
NZ Max's Avatar
wish I could advance my timing
Old Oct 9, 2001 | 11:16 PM
mykizism's Avatar
does advanceing the timing on the car really help that much?
any top end gains? or just mainly low end?
Old Oct 9, 2001 | 11:18 PM
mykizism's Avatar
im not sure if i advanced or retarted my timing
because one day i took my distributor cap off.. to clean everything and make sure everything is running ok.. i put it back on straight, but im not sure if that didnt anything to the timing..
Old Oct 9, 2001 | 11:25 PM
SkyMax's Avatar
Just get a timing gun and check it. There are some places that have rentals or you could even ask to borrow one for a few minutes.
Old Oct 9, 2001 | 11:31 PM
mykizism's Avatar
ok thx do u know what the stock timing is?
Old Oct 9, 2001 | 11:47 PM
SkyMax's Avatar
Stock timing should be @ 15 degrees.
Old Oct 9, 2001 | 11:56 PM
mykizism's Avatar
thanks a bunch
appreciate the help
Old Oct 10, 2001 | 05:49 AM
flyry110's Avatar
i advanced mine in my ve to 18-19 degrees. i wanted to be sure i didn't go too far because then the computer takes over and retards it for me anyway, yeah, i run 94 when it's advanced. i knocked it back when gas prices went up, but now i can advance it again, even though VE's are supposed to run premium anyway. hehehe oops. anyway, i notice better throttle response and the engine seems much peppier. i was pleased, but it was a bizach being able to see the timing marks on the harmonic balancer.
Old Oct 10, 2001 | 09:20 AM
AKAICEBERG's Avatar
timing marks
I have spoken to Nismo8780 about advancing the timing, and he broke it down for me baby style. The is one things I just can get though. Where exactly are the timing marks. I know there on the timing cover, but I looked and didn't find them. Maybe they are covered with crude.
Oh and from what I understand I have to turn the distributor when the car is on, but won't that shock me??? I guess if I use a towel to turn it that I won't get shocked.
Thanks,
Kevin
Old Oct 10, 2001 | 01:07 PM
Matt93SE's Avatar
STFU n00b!
the timing marks are on the crank pulley itself... there's a notch on the timing cover that you line up to the crank pulley notches when setting your timing.. each notch on the pulley is (I THINK!) 5 degrees. so "stock" timing should be the 4th notch (0,5,10,15) .. move your timing up one notch, by turning the distributor clockwise (looking from the top of the engine)
As long as your hands are dry, you shouldn't have any problems with getting zapped. Try not to grab the spark plug wires or ends.. grab the flat parts of the distributor where there aren't any wires. it won't physically hurt ya anyway, just don't hold onto it forever if you do get shocked.
Old Oct 10, 2001 | 01:42 PM
SEguy182's Avatar
theres a confidence booster...if it hurts let go
Old Oct 10, 2001 | 07:11 PM
mykizism's Avatar
matt i dont get it.. how are you suppost to see the timing marks when they are on the crank pully. because from up top.. trying to view down its almost impossible to see the (or even point) the timing gun at the crank pully.. i just installed a new udp so the crank pully timing marks are marked in white (thank god) but yah how am i suppost to know what the timing is ?? i never used a timing gun so i have no clue what questions to ask.. but im gonna buy a timing gun in the next day or so and play with it..
Old Oct 11, 2001 | 02:11 AM
lp's Avatar
lp
Buy the equipment, hook it up and the first time you point the gun down at the pulley you'll understand. The timing markers will show themselves in plain view.
VG adjustment is a 60 sec (minor) mod guys, don't expect the world from it.
Old Oct 11, 2001 | 08:51 AM
flyry110's Avatar
not on my VE i had to fenangle that thing down in there before i could see the marks. and even then it was jumpin all over, i had to get it to stock timing before i advanced it. i had it way advanced and the computer was compensating.
Old Oct 11, 2001 | 10:18 AM
Luan's Avatar
Can anybody tell me the accuracy when installing the timing belt !
Is it possible if there is just a.. little off..?
My case, the car run just fine..(I think the timing is ?? OK ??..not sure.),
but it is not the same as before, there is huummm when it starts changing to the next gear (A/T transmission).
All these things just happen after the water pump and the timing belt changed.
Thank you.
Old Oct 11, 2001 | 05:13 PM
nardo'89SE's Avatar
dyno number on adv. timing
can someone post there dyno'ed gains from adv. timing, not the butt dyno the real deal
Old Oct 11, 2001 | 07:39 PM
mykizism's Avatar
hahahahhahaha yah i bought my self a timing gun today.. yah its VeRY in plain view.. omg its soo cool looking ^__^
Hondarydr
Dec 30, 2024 06:15 PM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
Starrider
Sep 17, 2015 07:26 AM
FlaMark
25
Aug 28, 2015 10:15 AM
305head
Aug 26, 2015 09:03 PM
