aahh!! indiglo problems (long)
Old Oct 16, 2001 | 02:56 PM
djslinkyz's Avatar
okay i installed the indiglo's. i thought i did a pretty clean job too. this is what i did. took apart the dash and all, to get the cluster out. took the cluster out, took the clear and black things off, put the indiglo's on, wired them up, put everything back together, and now i got problems...
1. (fixed)
2. (fixed)
3. (fixed)
4. (fixed)
5. (fixed)
6. (fixed)
7. Indiglos only work when key is either in OFF or not in the ignition.
8. (fixed)
so far, that's it. i hope i don't find any more problems...
Old Oct 16, 2001 | 03:11 PM
MaxSE's Avatar
Re: aahh!! indiglo problems (long)
1. (fixed)
2. (fixed)
3. (fixed)
4. power windows don't work, except for the driver's window.
5. speedometer doesn't move.
6. tachometer moves a little bit. (i know they can move around because after i put the indiglo's on, i tapped the needles and they moved.)
WOW! that really sucks man. I hope you didn't mess with the needle otherwise you're gonna have to get them recalibrated. I hope i could help you out but i'm not really sure.. what kinda car you got? GXE or SE?
Old Oct 16, 2001 | 03:18 PM
djslinkyz's Avatar
Re: Re: aahh!! indiglo problems (long)
i didn't do anything to the needles except move them a little so i could get the indiglos over them. i have a GXE
Old Oct 16, 2001 | 03:22 PM
maxmonkey's Avatar
then you should be fine with the needles, I moved the tach and speedo needle a lot while I was installing mine, and everything works fine for me. Check the connections in the back, there're three. Make sure the connectors are clean.
Old Oct 16, 2001 | 03:26 PM
djslinkyz's Avatar
hey maxmonkey, where did you wire the power and ground to? just wondering. i'm gonna go through all the steps again.
Old Oct 17, 2001 | 07:34 PM
BIGDOG's Avatar
Well dude that sucks. Ive gottenm ine in but now im afraid to actually put them on. LOL How hard was it??? I put a set on a 2000 honda civic. These werent that big of a deal. Ive taken the dash apart once already. The needles are what in worried about. Ohh And one more question. What is the block cut out for on the gas/temp guage??? I dont have a light or anything there. ANd I got the right ones I hope. LOL
Bigdog
Old Oct 17, 2001 | 08:28 PM
djslinkyz's Avatar
Bigdog
its for the O/D off light. i guess you have a 5 speed. the install was easy. the only problem i have now is that the gauges turn off when i put the key in ACC or ON, which means i can't drive at night. but that's just a wiring problem, and i'm gonna try to fix it tomorrow after school. i figured out the window problem... when taking stuff apart/putting stuff back together, i acidentally hit the power window lock button... lol
Old Oct 18, 2001 | 07:36 AM
Maxirasta's Avatar
Is it possible to put the 145mph gauges in my GXE that has stock 120mph gauges?
Also are these the gauges off of Ebay that you guys are talking about?
Old Oct 18, 2001 | 11:01 AM
MaxSE's Avatar
ur needle would be telling you the wrong speed... so if you're going 35 it might say sometjhihg higher or lower...so basically no
Old Oct 18, 2001 | 12:30 PM
MadMaxBrent's Avatar
If you have the electronic speed sensor on your Maxima then you can swap the gauges. The calibration of the gauges is done at the gauges themselves and the GXE and SE autos both use the same speed sensor (The 5 speeds use a different sensor I believe - due to the transmision differences). So if the calibration on the gauges you are putting in are correct then you should be fine.
Brent.
Old Oct 19, 2001 | 01:34 AM
Evil Yak's Avatar
matts95max
Apr 23, 2025 10:44 AM
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
Maxima Pride '07
Sep 12, 2015 07:29 AM
Maxima30
Sep 7, 2015 06:13 PM
