fixing coding issues.......
Old Sep 21, 2007 | 11:12 AM
Mr.Davon24's Avatar
Ok so I went to check the ecm today and pulled off these four codes.
34- ks ( read some where these basically are useless on vgs)
23- thorttle valve circuit switch open
45- fuel injecetor leak (ca models only)
51- Fuel injector circuit open (Ca models only)
just incase ones missed it I have a Vg. Can anyone help me out to getting these fixed. Only problems that in do have is hesitation at low Rpms.
Old Sep 21, 2007 | 11:49 AM
internetautomar's Avatar
mod or sell?
find the dead/failing injector
Old Sep 21, 2007 | 12:14 PM
Mr.Davon24's Avatar
wouldn't a bad injector stop one of the cylinders?
Old Sep 21, 2007 | 12:32 PM
mod or sell?
it depends on the type failure.
absolute failure will, but clogging and poor spray pattern / insufficient flow won't.
Old Sep 22, 2007 | 04:37 PM
Mr.Davon24's Avatar
any other suggestions
Old Sep 22, 2007 | 04:45 PM
Greeny's Avatar
¯\(°_o)/¯
I would clear the ecu first,it's possible some of the codes are old(previously fixed,but never cleared)
Disconnect the battery cables for about 15-20 minutes,then drive as normal for a few days/then recheck the codes
Old Sep 22, 2007 | 08:47 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
setting to move IV on the VG ECU clears codes. besides they only last for 50 starts. Just gotta verify in mode III again. if you get a 55, you're good. then drive around like he said
Old Sep 22, 2007 | 09:31 PM
Mr.Davon24's Avatar
will do thanks guys
Mar 12, 2020 12:06 AM
homeofbacon
Sep 23, 2015 07:17 PM
220k+ A32
Sep 22, 2015 03:08 PM
Pnjboyzz
Sep 21, 2015 12:41 PM
Steven Orozco
Sep 12, 2015 10:41 PM
