headlight wiring help
Old Oct 18, 2001 | 01:37 PM
MaDMaX024's Avatar
how would i go about wiring my corners so they are bright with the headlights (low and hi beams) and dim with the parking lights? i was thinking splice the power to the headlights into the corner along with the stock power wire for it then cutting the turn signal lead to the corner power wire so it will stay on dim when the headlight wire isnt supplying power. will this work? what color is the power wire for the headlights?
thanks
Old Oct 18, 2001 | 01:42 PM
«§»Craig B«§»'s Avatar
Re: headlight wiring help
thanks
I'll draw up a little diagram when I get home. Shouldn't be too hard.
Craig
craigbrace@hotmail.com
Old Oct 18, 2001 | 02:34 PM
MaDMaX024's Avatar
Re: Re: headlight wiring help
Craig
i was just out there, i'd like to return the wiring to stock and cut the wires somewhere else so the wiring at the corner is stock (except for the foglight lead, but tahts ok). i was thinking, i would look under the relay for the corner lights and find the lead that goes to the turn signals, cut that and attach it to the headlight relay. i just need to know where the headlight relay is (i've probably overlooked it several times as i wasnt looking for it) and which wires to cut at the corner relay and which to splice to at the headlight relay.
Old Oct 18, 2001 | 03:03 PM
Re: Re: Re: headlight wiring help
too late, I just drew this up
this way is really easy and just requires adding one wire and cutting another
check it out, if you want ot do it your way, I could look into it, but later because I'm eating dinner right now
email me craigbrace@hotmail.com
Old Oct 18, 2001 | 03:21 PM
MaDMaX024's Avatar
Re: Re: Re: Re: headlight wiring help
well, that looks really easy. i suppose i can do it that way. the only thing i'm wondering is, how would the dim filament turn on with the headlights off?
Old Oct 18, 2001 | 08:32 PM
Re: Re: Re: Re: Re: headlight wiring help
the "dim" filament is controlled by the red/yellow wire going into each corner so I'm not even changing that
the only thing I did was make the bright filament come on with headlights
I supposed teh right way to do it would be with a little more complicated wiring and/or a relay but this way should be fine too
if you want, I'll explain the other way for you, but it'll have to be tomorrow because I dont have much time now
Old Oct 19, 2001 | 11:41 AM
MaDMaX024's Avatar
Re: Re: Re: Re: Re: Re: headlight wiring help
OH!!!!
completely misunderstood. i thought you were just talking about the red and green/white wires AFTER the plug. i'm dumb
i'll do what you said tomorrow. time for work
thanks again
Old Oct 19, 2001 | 12:38 PM
Re: Re: Re: Re: Re: Re: Re: headlight wiring help
OH!!!!
thanks again
let me know how it goes
good luck
Old Oct 20, 2001 | 11:20 AM
MaDMaX024's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: headlight wiring help
good luck
well, i just finished. took me about an hour because i'm an idiot and didnt remember how to wire the corners stock again, basically my wires are all F'ed up and ugly, but it works. you da man, thanks alot!
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
