timing question.
Old Nov 5, 2007 | 03:53 PM
helps
timing question.
so i decided to check the timing today and it was 10 degrees advanced. did the person i bought it from do this to get more power?( i heard you could advance a couple degrees to get a little more power but something about ruining your lifters) the reason i checked it is because my car starts like crap in the morning/when its very cold. and recently the starter started grinding. pretty much its impossible to turn the crankshaft when its cold.and then when i did start to turn over it would die just like it wasnt getting gas or something. now if i held the gas to the floor it would rev up and then when i let off it would idle and slowly drop then die. i have to hold the gas for a couple seconds for it not to die. runs fine after that and when its not cold starts great.
Old Nov 5, 2007 | 03:55 PM
helps
o yeah and its a vg and i timed it to 17 degrees now.
Old Nov 5, 2007 | 03:57 PM
Greeny's Avatar
¯\(°_o)/¯
Have you replaced the bad injectors yet?
---->http://forums.maxima.org/showthread.php?t=540724
Old Nov 5, 2007 | 04:00 PM
helps
yes sir.
Old Nov 5, 2007 | 04:01 PM
helps
also having good injectors only fixed how it was running lean at idle. did not fix the stumbling at all.
Old Nov 6, 2007 | 09:41 PM
CMax03's Avatar
Did you pull your water temp sensor and measure it's hot and cold resistance?
Old Nov 6, 2007 | 10:31 PM
KRRZ350's Avatar
My vote's for starter, they're finicky when cold....... and it IS grinding.
Old Nov 7, 2007 | 04:50 AM
truckinusa's Avatar
strange, was trying to get my pic to post? Sorry
Old Nov 7, 2007 | 08:37 AM
helps
this is the 8th starter ive had and they all seem to stick at a month in. and i really dont want to put another flywheel in soon. its brand new. and none of this explains why after the starter does get going why it just stumbles to a halt.
Old Nov 7, 2007 | 11:30 AM
internetautomar's Avatar
mod or sell?
cheap crap quality starters it sounds like you're getting.
Old Nov 7, 2007 | 12:37 PM
helps
any recomendations? tried nissans, autozones, checkers, some nismo cheap aftermarket thing none seem to last.
Old Nov 7, 2007 | 04:03 PM
mod or sell?
stock going to major chains and visit the mom and pop stores in the area that sell to the local garages. They have more interest in stocking a quality product because the stores don't want a comeback.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
