Replacing struts (need advice)
Old Nov 12, 2007 | 10:42 PM
gapboi210's Avatar
I replaced my struts already with some Gabriels. (yeah I know). When I got this Max, the struts were so bad the car bounced everywhere. Gabriels were all I can budget at the time. Well the Gabriels are horrible! The car still bottoms out when it shouldn't. I think I am going to go with KYB. However, there were rubber sleeve looking things on the struts when I pulled the OEM ones off. I am guessing they are bump stops? Mine were so rotted that I threw them out. Where do I get more? I need to do the strut mounts too.
Old Nov 13, 2007 | 02:14 AM
disgruntled's Avatar
pepboys, autozone, napa, dealer, internetautomart, forum just to name a few. They're not that hard or expensive to come by, I was just surprised that you didn't get one with the KYB. GL.
Old Nov 13, 2007 | 08:20 AM
gapboi210's Avatar
so the struts usually come with that rubber piece?
Old Nov 13, 2007 | 08:29 AM
Greeny's Avatar
¯\(°_o)/¯
No,the bump stops are a separate item..you can find the bump stops/strut bellows at most major auto parts stores for about $20 per strut.
Old Nov 13, 2007 | 10:27 AM
internetautomar's Avatar
mod or sell?
Personally, I'd get tokicos over the KYBs even though I can actually compete on KYB pricing again (need to update the site though)
Old Nov 13, 2007 | 11:48 AM
gapboi210's Avatar
this sounds like it is getting expensive fast, struts + mounts + bump stops + alignment
Old Nov 13, 2007 | 11:49 AM
mod or sell?
cars aren't supposed to be cheap.
Old Nov 13, 2007 | 12:00 PM
Greeny's Avatar
¯\(°_o)/¯
go buy a new(er) car,after you make the first months payment,you could have bought new struts/mounts/bump stops and an alignment.
Old Nov 13, 2007 | 12:36 PM
gapboi210's Avatar
i know it just needs motor mounts and a paint job and struts and...... I'll just start tackling things one paycheck at a time and get it all done.
Old Nov 13, 2007 | 12:38 PM
92 Max's Avatar
Look at the KYB site. They make bump stops for the front and another for the rear shocks.
Old Nov 16, 2007 | 12:36 AM
Quickywd01's Avatar
Are RACEKO struts good? Those are $160 and KYB's are $200. It's a daily driver what should I get? I had a pretty good pull to the right and now with the new tires it seems to be gone; weird. I just got some "new" tires and I want or need to get brakes.
Old Nov 16, 2007 | 04:44 AM
Greeny's Avatar
¯\(°_o)/¯
Stay away from the generic/no name brand struts...
List of the best according to quality/price..
1. Koni reds./about $600,but they are the best.
2. Tokico./About $300,the oem struts were made by this company.
3. KYB,meh,ok..but a little soft from what i hear..
Old Nov 16, 2007 | 01:26 PM
Quickywd01's Avatar
Looking at your list I'd get some Tokico's but I have to replace so much stuff on my max that every dollar counts lol. Being the broke, cheap *** college student that I am, I'll go with the cheaper stuff because it's better than what I have. My car bobs all over like a boat. I'll get the kyb's. Just out of curiosity are those cheaper struts crap or just no name stuff?
Old Nov 16, 2007 | 04:48 PM
Darkwing48's Avatar
Hey, I survived on Cup of Noodles ($.25) for 3 months to get my computer and paid rent when I was dorming at my University. If I can do it, you can too.
Can you get Koni from Autozone?
Old Nov 16, 2007 | 04:52 PM
Greeny's Avatar
¯\(°_o)/¯
lol..nope..
http://www.shox.com/
Old Nov 16, 2007 | 05:52 PM
Quickywd01's Avatar
I already ordered the kyb's, I hope I get them before I move.
Old Nov 16, 2007 | 10:35 PM
Quickywd01's Avatar
I was going to get an alignment but do I have to wait till my new struts are in before doing that?
Old Nov 16, 2007 | 10:51 PM
helps
yes
Old Nov 17, 2007 | 05:37 PM
mod or sell?
you don't HAVE too, but you will want to do it again once the struts are in.
Old Nov 29, 2007 | 04:29 PM
writes1's Avatar
is there a website that gives step-by-step instructions on how to replace my struts? Also, will I need to get my aligment done once I do this?
Old Nov 29, 2007 | 05:25 PM
Quickywd01's Avatar
You should have an alignment when doing suspension work. I have my kyb's in my room too. http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Nov 29, 2007 | 05:28 PM
gen3fan's Avatar
http://autozone.com/home.htm
Good luck with the KYB's. They work for me. You'll notice slightly better handling, slightly stiffer ride, good all around.
Old Nov 29, 2007 | 05:30 PM
gen3fan's Avatar
arrg u beat me
Old Nov 29, 2007 | 05:32 PM
mod or sell?
I've got rear tokicos in my garage still.
Old Nov 30, 2007 | 07:46 AM
mrkanda's Avatar
Taking my Maxima to the Max!
related point: when replacing the struts yourself, obviously you have to use spring compressors to remove the springs. Are the dual "pincher screw" types safe and easy to use?
Old Nov 30, 2007 | 01:45 PM
92 Max's Avatar
I used the double screw type with meaty hooks on either end. Be very careful doing this and make sure the hooks are NOT slipping or moving as you tighten. I bought some cheap Harbor Frieght ones and they stripped before I got to the last spring so I had to go out to Sears and buy real ones. The fronts require you to tighten them until the part of the spring that is in the compresser almost touches. Then the top spring mount is still touching the spring, but with some force you can move it. You just must push down on the spring mount during assembly to get it to to point where you can spin on the bolt.
Old Nov 30, 2007 | 02:40 PM
Alex_V
You can rent spring compressors from auto zone/advance and other places. You just pay about $50 or so and when you return the tools you get it all back. So its pretty much free.
~Alex
Old Nov 30, 2007 | 05:42 PM
Greeny's Avatar
¯\(°_o)/¯
I want one of these..
http://www.youtube.com/watch?v=0Mt1UBTp0zk
The machine also..
Old Nov 30, 2007 | 08:42 PM
ColombianMax's Avatar
If you're using J hook strut compressors, I suggest putting a vice grip on on the spring where the compressor sits so the compressor doesnt slide around. Its safer if you ask me.
Old Nov 30, 2007 | 08:59 PM
gapboi210's Avatar
Hmmm the part that hooks the spring looked flimsy. We have a spring compressor at the shop that isn't electric and the parts that hook on the spring are big meaty things. And shouldnt she keep the guard down while the spring is compressed?
Old Nov 30, 2007 | 09:12 PM
BenStoked's Avatar
Jesus was a Zombie.
Originally Posted by MyGreenMax94
yeah!
a girl in a short skirt to mechanic my car!
I want one,too!
she really knows how to strut her stuff!!!
jskirwin
Jun 8, 2016 08:49 AM
95Maxi
35
Sep 2, 2015 10:37 AM
District
Aug 15, 2015 08:23 PM
laparka66
Aug 6, 2015 09:36 AM
maxima297
Aug 3, 2015 12:50 PM
