OEM GXE Fog Light Wiring (who the heck has 56K these days?)
Old Mar 4, 2013 | 03:58 PM
  #41
CapedCadaver's Avatar
Call me Wookiee Goldberg
Originally Posted by nismax1994
With the gxe fogs you will get lense+reflector. They are not like se at all. Even the Bosch seemed cheapo compared to the heavy se assembly. They have a metal spring/tab holding the lense on as well as very different mounts. I just ordered some no name ones from amazon. I will share pics when they arrive. I like the smaller size of the gxe fogs.
They remind me a lot of what's on my Pathfinder also... (not mine, but basically identical to mine)
Old Mar 4, 2013 | 10:49 PM
  #42
DMad8724's Avatar
Im curious whether the glass would be removable (so I can add yellow capsules) on the GXE fogs. Ive tried several different ways with the SE fogs and I cannot get the glass alone off. Too bad, too, since Ive got some capsules that would fit inside them perfectly
Old Mar 5, 2013 | 06:21 AM
  #43
DanNY's Avatar
Ad·min·is·tra·tor
the stock SE ones?
there are 2 phillips screws behind the housing. undo those and the glass falls out revealing a H3 bulb.
Old Mar 5, 2013 | 09:37 AM
  #44
DMad8724's Avatar
Originally Posted by DanNY
the stock SE ones?
LOLOL. Im talking about removing the glass from the reflector itself. I know the reflector + glass removes from the housing with those screws. Im saying id like to seperate the glass from the reflector and add yellow capsules.
Its possible to remove the H3 bulb holder and add capsules. But once you move that original bulb holder; there goes the beam pattern..
Old Mar 9, 2013 | 09:03 PM
  #45
nismax1994's Avatar
Generic GXE fogs arrived today. They are glass, lens has "Luxpro" etched into it, sticker says "Eagle Eyes." They appear to be good quality.
Here's a comparison to the OEM SE fog:
To answer DMad8724's question the lens seems to be crimped onto the reflector, it doesn't seem practical to try and separate the two.
My question: does one of the lights need to be inverted? How to tell which one?
Old Mar 10, 2013 | 01:42 PM
  #46
DMad8724's Avatar
foglight glass is always the same for both sides
ie you dont order foglight glass L and R, you order 2 of the same part number..
Old Mar 10, 2013 | 01:55 PM
  #47
maximo018's Avatar
Man I haven't seen SE fogs in a while nor been able to find them.
Old Mar 11, 2013 | 05:36 AM
  #48
there is an "up" right? I think it matters which way they go in... since the light is intended to be aimed downward only.
Also does the SE fog have a plate inside it at the same height as the GXE fog's total height? Kinda looks like the actual light-output zone is the same size.
Old Mar 11, 2013 | 06:32 AM
  #49
DanNY's Avatar
Ad·min·is·tra·tor
ohhhhhh....
beam pattern...what that even a thought when nissan made these housings?
Old Mar 11, 2013 | 12:09 PM
  #50
DMad8724's Avatar
Caped: yeah the se fog has a cutoff shield in it
DanNY: all i know is without modification the SE fogs have a crisp, rectangular ~beam pattern~ lol
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
