Regulator/motor help!!!!
Old Oct 26, 2001 | 06:01 PM
abdiddy's Avatar
I am trying to replace my regulator for my passenger side window. I took the door panels off and unscrewed thr regulator and motor but cant't get thge old motor and regulator out of the little hole in the door. I read that there are screws the hold window to the regulator/motor but I can't get to them because my window is stuck all the way up. How do I lower the window manually?
Old Oct 26, 2001 | 09:52 PM
MONTARABOB's Avatar
Re: Regulator/motor help!!!!
Cut the wire. Its the only thing holding pressure. Prob. bound around spool.
Old Oct 27, 2001 | 06:30 AM
«§»Craig B«§»'s Avatar
dont cut the wire like the other guy mentioned
yes, you do need to take those screws out at the bottom of teh window
either plug your door switch back in and try to roll it down (I assume this doesn't work though because your regulator is messed up), otherwise, just grab each side of the window between your hands and slide it down rocking back and forth
that should do it usually
Old Oct 27, 2001 | 06:58 PM
Rancid90SE's Avatar
i dont know exactly what is being talked about but if its the rear doors,to give you room you might wanna just take the window out,i install auto glass for a living,though i never did a backdoor glass on a 89-94,but if its anything like a 95-99 or a 93-97 altima,you may have to take the weather stripping out to remove the window,window comes off the regulator very easy,2 10mill bolts..and if you need to get the window back in put it back in without the weatherstripping,then spary silicon or some kind of lubricant and slide them in while window is down
Teaner
43
Jul 25, 2009 10:06 AM
coachholland
Mar 2, 2008 02:31 PM
maxfive-O
Feb 21, 2008 01:55 AM
bvtran
Sep 1, 2005 05:32 AM
bklyngirl89
Nov 12, 2002 09:05 AM
