ECU codes
Old Oct 28, 2001 | 06:14 AM
bmw88rider's Avatar
ECU codes
Hey Guys. Thanks for all of the good information so far. You all rock! Question for you all. I've been having engine problems and I pulled the code and it was 5 long and 1 short. I found a site at one time to tell you that stuff but I didn't bookmark it... BTW, I have a 94 SE with the 5 speed. One more unrelated to the engine problem question. I have the leather interior but no power seats....Looking at the information, I thought that was required? Am I wrong?? Thanks guys
94 SE 5 Speed
White/Black leather
67K Miles...(still a virgin....lol)
Old Oct 28, 2001 | 06:34 AM
N34JZ's Avatar
Needs non-Maxima Friends
power seats arent required
as far as i know in an se my 92 se has leather and no power seats.
but i think my leather is aftermarket.
Old Oct 28, 2001 | 08:38 AM
bmw88rider's Avatar
That's interesting that the Power Seats aren't required. Back to the other question....Are the ECM codes the same for 1994 as the codes for 95-99?? I found a list of 95-99 codes but none for 94. On that list for 95-99 the code 0501 is not on there. Odd. Also, I found that it is triggering my knock sensor. Help....PLEASE!! This is driving me nuts.
Thanks,
Mike
Old Oct 28, 2001 | 11:04 AM
MadMaxBrent's Avatar
Steve has a good FAQ site as posted below. I don't see the code you mentioned though.
Brent.
http://web2.airmail.net/scutchen/max_faq/
Old Oct 28, 2001 | 11:18 AM
Bman's Avatar
Okay, here you go my friend, I just looked in my FSM for my 92 SE and here's what I came up with. The pulses can be directly translated into numbers. 5 longs = 5 tens, and 1 short = 1 ones, so the code is 51.
Code 51 is the "injector circuit" and malfunction detected when "injector circuit is open". It tells you to check the: "harness and connector, and injector(s)"
Hopefully my 92 VE30DE codes are identical to your 94 codes (I don't see why not). Good luck!
Old Oct 28, 2001 | 11:46 AM
bmw88rider's Avatar
Sounds logical
Thanks a lot. The dealer replaced 2 injectors and checked the rest when I bought the car.......Sounds like they didn't get all of the clips tight. Lovely Downers Grove Nissan in Chicagoland area. AVOID them at all costs. They have caused me nothing but problems. That would cause the low end miss and the loss of power. Can you scan a copy of those and send them to me?? If so, That would be great!! Let me know.
Old Oct 30, 2001 | 08:57 PM
jwtarbaj's Avatar
Unfortunately if only 2 were replaced more may have gone bad. It seems to be a common problem on 3rd gen Max. Knock on wood I haven't had a problem yet.
John
91 Max SE 5-spd
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
