Rear bearings
Old Feb 10, 2008 | 05:02 PM
mikekantor's Avatar
Rear bearings
Do they need lubricant during assembly? I didnt see anything of the sort when taking them apart, but as far I know they have never been removed so perhaps it wore away over 15 years.
Also, I practically destroyed the caps back there, guess I'll have to buy a pair...
Old Feb 10, 2008 | 05:26 PM
BenStoked's Avatar
Jesus was a Zombie.
nothing in the fsm...
Old Feb 10, 2008 | 05:46 PM
jonmandude's Avatar
They are sealed bearings. When they wear replace them, no maintenance.
Old Feb 14, 2008 | 06:41 PM
Matt93SE's Avatar
STFU n00b!
late response here, but put a thin layer of grease on the axle stubs to protect them from corrosion. that's about it.
the bearing itself is sealed and should need no lube, but I'll pack a thin layer inside the hub cap too to prevent air/moisture from getting in and doing any damage.
Old Feb 15, 2008 | 07:45 AM
mikekantor's Avatar
Thanks for clearing up my terminology, yes I was referring to the axle stubs... not the bearings themselves.
Is there any specific type or brand of grease for this?
Old Feb 15, 2008 | 09:47 AM
Matt93SE's Avatar
STFU n00b!
take a look at the FSM and it will probably show a certain type of grease.
I just use "axle grease" or "wheel bearing grease" from the parts store.
Old Feb 15, 2008 | 04:41 PM
jonmandude's Avatar
I like anti-seize
Old Feb 16, 2008 | 07:00 AM
Matt93SE's Avatar
STFU n00b!
Originally Posted by jonmandude
I like anti-seize
be wary of using anti-sieze near bearings. it contains small particles of copper or aluminum or graphite, which can build up on the bearing surfaces and cause damage to the bearings. grease is just a 'slime' that doesn't have particles in it and is better to use near bearings.
Old Feb 16, 2008 | 01:20 PM
jonmandude's Avatar
Thanks for the tip.
Old Feb 17, 2008 | 06:06 PM
mikekantor's Avatar
The 'slime' worked quite well, I now have a can of it that will last a few decades.
Old Feb 17, 2008 | 08:56 PM
Matt93SE's Avatar
STFU n00b!
heh.. yeah. you need just one small pea-sized blob of it and you gotta buy a 12oz tube..
matts95max
Apr 23, 2025 10:44 AM
flu2000
Sep 8, 2015 02:23 PM
jfl330
Sep 4, 2015 01:44 PM
