Broken Screw!?
Old Feb 16, 2008 | 10:51 AM
coolsun's Avatar
Broken Screw!?
I have Found a broken screw in the rear vavle cover an i dont What to do
I will be doing a gasket change but i want to buy all the items before i start
I found a screw that wont come out and i dont know wat to do???
there is like a nut on the end
any help on how to take it out and the thing i need replacement on?
thanks
http://http://s262.photobucket.com/albums/ii104/coolsun888/?action=view&current=DSC01337.jpg
http://http://s262.photobucket.com/albums/ii104/coolsun888/?action=view&current=DSC01335.jpg
http://s262.photobucket.com/albums/i...t=DSC01339.jpg
Old Feb 16, 2008 | 11:16 AM
goon9's Avatar
Take off the intake manifold...
Remove the valve cover...
Extract the broken bolt....
Replace it all in reverse order.
Have fun with it
Old Feb 16, 2008 | 12:00 PM
coolsun's Avatar
can u tell tell me the part i need to buy? for the broken bolt
Old Feb 16, 2008 | 12:40 PM
goon9's Avatar
You can come up with something at the hardware store with some Common sense.
Or take it to the nissan counter for the exact part.
Old Feb 16, 2008 | 01:25 PM
Hectic's Avatar
If there's enough of a chunk, cut a slit at the top with a dremel cutting bit and unscrew with a flathead.
Old Feb 16, 2008 | 05:29 PM
coolsun's Avatar
The dealers in Brooklyn r rude n they dont feel like doing s**t for anyone
thanks anyway ill try to find a something at home depot to take its place
Old Feb 16, 2008 | 05:42 PM
Greeny's Avatar
¯\(°_o)/¯
http://www.courtesyparts.com/betasit...4-p-41679.html
Old Feb 16, 2008 | 06:22 PM
Matt93SE's Avatar
STFU n00b!
is it actually broken, or is it just unscrewing the stud from the top of the head?
Old Feb 16, 2008 | 06:30 PM
Greeny's Avatar
¯\(°_o)/¯
+1
A few of my valve cover studs unscrew from the head instead of the round nut.
Old Feb 16, 2008 | 07:26 PM
mikekantor's Avatar
A long time ago I broke two of them on my front valve cover and failed at the extraction. Its still that way today, 0 leaks.
Old Feb 16, 2008 | 08:03 PM
coolsun's Avatar
so this would include 24 studs?
Old Feb 16, 2008 | 08:22 PM
mikekantor's Avatar
No, and it doesnt include the nut or the washer... in case you wanted those.
Old Feb 16, 2008 | 08:27 PM
coolsun's Avatar
so only one stud?
Old Feb 16, 2008 | 08:34 PM
BenStoked's Avatar
Jesus was a Zombie.
mau, only one stud.
Old Feb 16, 2008 | 08:36 PM
Matt93SE's Avatar
STFU n00b!
yeah.. nissan's proud of little parts like that.
I ordered a complete set of the rubber bushings, cup washers, and acorn nuts for my front valve cover on the engine rebuild (can't see the rear, so screw them)..
cost me like $75 just for a dozen washers and nuts.
Old Feb 16, 2008 | 08:43 PM
BenStoked's Avatar
Jesus was a Zombie.
why can't you just go to the hardware store and get some 8.8 studs/washers/nuts/etc.? you can take old ones in to compare size, thread pitch, and whatever, all for less than 1/4 the price. am I missing something?
Old Feb 17, 2008 | 12:29 AM
NismoChi's Avatar
What do you mean it won't come out? do you mean the whole stud? Or the broken part? Can you screw it back in? The thing is, if it is broken at the base, it would still come out leaving the broken part on the head.
This is a pic of one of the stud that i took not two days ago, so the memory is still kind of fresh.
Old Feb 17, 2008 | 01:32 PM
mikekantor's Avatar
I bought the nuts at a hardware store, but had to empty a few of them to get enough for a complete set.
Old Feb 17, 2008 | 01:34 PM
mikekantor's Avatar
You could probably find the stud, ive found the nuts. The washer and bushing each have a unique shape and you wont find anything exactly like it.
Old Feb 17, 2008 | 01:54 PM
coolsun's Avatar
so u have to drill out the stud right?
Old Feb 17, 2008 | 02:57 PM
internetautomar's Avatar
mod or sell?
there's a nut at the bottom of that stud to take it out with.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
doctorpullit
Mar 29, 2016 11:08 AM
sliptap
Sep 30, 2015 05:57 AM
thenewguyy
Sep 12, 2015 11:12 AM
