Whats your max weigh?
Old Feb 16, 2008 | 08:33 PM
akurtzer57's Avatar
Searched through the threads to find out what peoples maxima's weigh after a little weight reduction, and what all did you take out to get it there. I know mine weighs 3300lbs with me in and a 1/4 tank. (Using a grain elevator scale.)
Old Feb 17, 2008 | 10:30 AM
subs1000w's Avatar
mine wieghs about the same with me in it as of about 4 years ago thats no reduction im sure you could get it down below 3k pretty easy but you start down a slippery sloap to it not being a maxima any more i figure its easier to add hp to make up for the wieght then the other way around
Old Feb 17, 2008 | 11:08 AM
goon9's Avatar
I'll have to weigh mine when I'm done hacking it all up.
Old Feb 17, 2008 | 11:59 AM
VEvolution's Avatar
I miss my VE
mine is all carbon fiber and still weighs 3200lbs. damn VE
Old Feb 17, 2008 | 04:48 PM
mattdouken's Avatar
with me in my car and a full tank, it weighs 3088.I weigh 220.so yeah a good bit of weight taken out if i say..
I weighed it at a landfill..
Old Feb 17, 2008 | 06:48 PM
nismax1994's Avatar
I weighed in at 3260 carrying a payload of 4 white trash bags, and at least 1/2 tank of gas.
Old Feb 18, 2008 | 05:47 AM
internetautomar's Avatar
mod or sell?
you weighed it with 4 old ladies
Old Feb 19, 2008 | 07:50 PM
nismax1994's Avatar
minus the 4 old bags i'd say the Maxima is light for its size.
Old Feb 20, 2008 | 11:13 PM
mattdouken's Avatar
yes it is,but what i was wondering,i plan to build a all motor 5spd.
And at what my car weighs now,i still have quite a bit to take out,not to mention cutting and stripping on the chassie (cant spell)but i cant find any videos or facts saying how fast a....well lets say a 250 hp non gutted maxima is.
I just want to know if im pushing 275hp all motor with it gutted to say 2700lbs including me..is it going to tear ***.and if so what kind of cars will it tear?
----those who cant drag----drift.
Old Feb 21, 2008 | 08:57 AM
akurtzer57's Avatar
If you want to get down to 2700lbs take out everything such as vents and a/c components there is alot of weight under our dashes. In order to get a 250-275hp all motor is going to cost ya. Your best bet is drop in a VG33 and build on top of that there is a few that have done it. Not sure what kind of numbers they got better luck asking them.
Old Feb 21, 2008 | 09:24 AM
subs1000w's Avatar
good luck man your gonna have trouble on both feats getting down to that wieght will require you to remove the entire interior and the bumper supports, gut the trunk and mayby a few other things and your also gonna have trouble getting 250 na hp out of any engine that bolts into a 3rd gen but if you did acomplish those 2 things and your talking 250 flywheel hp which is about 210-220whp it would proboly run in the mid 13s with good driver and sticky tires
Old Feb 21, 2008 | 10:36 AM
VEvolution's Avatar
I miss my VE
doesnt aaron92se run mid 13's with a VE nd nowhere near 220whp?
Old Feb 21, 2008 | 12:25 PM
BenStoked's Avatar
Jesus was a Zombie.
aaron ran a 12.89 with a ve and a 75 shot.
along with all the other mods...
http://www.nwpengineering.com/mods.html
Old Feb 21, 2008 | 01:44 PM
mattdouken's Avatar
that aaron guy has a really nice car,but its not a vg30e and he is using spray...but i would still guess its better to go turbo setup?any suggustions..
(sorry for getting off subject of weight.)
Old Feb 21, 2008 | 01:49 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
we lined up at the track. with his lower weight and higher power, he OWNED me. i ran a 16.3 and he ran a 13.0 on a crappy track surface. his NA stuff is working just fine, i'd say... but you'll have to ask him what his WHP is.. he has an on-car dyno.
Old Feb 21, 2008 | 02:02 PM
VEvolution's Avatar
I miss my VE
technically if hes sprayin nos i dont know how u can call that all motor, but okay.. how much HP does a 75 shot amount to?
Old Feb 21, 2008 | 02:08 PM
505max94se's Avatar
Are you still spraying 150-shot on your VE-5? How's that working out for you?
Old Feb 21, 2008 | 02:11 PM
505max94se's Avatar
It depends on the brand of jets that you're using... 75-shot with NX jetting (what Arron is using, iirc) is supposed to add 75 whp. 75-shot with NOS jetting is supposed to add 75 chp.
Old Feb 21, 2008 | 02:50 PM
BenStoked's Avatar
Jesus was a Zombie.
aaron says 310 hp, 265ft-lbs.
weight:2890 with aaron, so yeah, 2700 is possible with the ve...
and 13.7 n/a is still a respectable pull. i probably couldnt hit 17 sec with my car, but its pretty stock, and i don't know how to take off with a stick well....
Old Feb 21, 2008 | 02:55 PM
505max94se's Avatar
When did he say that? Is that with n2o and the gtech? Those numbers seem off. Usually non-high revving, n2o motors make more tq than hp...
Old Feb 21, 2008 | 03:05 PM
BenStoked's Avatar
Jesus was a Zombie.
it says that on the link i posted earlier, about 2/3 of the way down, right above his 1/4 times.
i dunno about the spray or gtech.
Old Feb 21, 2008 | 03:17 PM
subs1000w's Avatar
im no longer spraying my max at $40 per bottle fill up it was getting to expensive and it seemed i never had the bottle filled when i needed it not to mention i need the car to be as reliable as posible because my sister drives it alot now because thats the only way i was able to talk my parents into letting me keep the max plus my 2 f150s and my previa while living at home although some day when i move out the max will be fast but it wont get its power from a bottle
as far as what the car will run in the 1/4 my guess at mid 13s was just a conservative guess it my be able to run faster than that but i dont like to get peoples hopes to high
Old Feb 21, 2008 | 03:25 PM
505max94se's Avatar
Oh, I found it. Here's what it says.
"Estimated Horsepower: 310HP at crank and 265 fwhp"
These ratings must be with a 75-shot.
Old Feb 21, 2008 | 04:16 PM
BenStoked's Avatar
Jesus was a Zombie.
... because thats the only way i was able to talk my parents into letting me keep the max plus my 2 f150s and my previa while living at home ...
ditch one of the trucks and the minivan! the max is funner, and you still have a truck!
Old Feb 21, 2008 | 06:01 PM
mattdouken's Avatar
ok what my real goal is,i just wanna take out mildly built civics ,integras,240 or just be able to run with them,and no one suggest i get one of the cars i just listed....i want it out of a vg30e 5spd maxima,and i dont want to put money into it and work if is still not gunna run with those type of cars..
Old Feb 21, 2008 | 06:41 PM
VEvolution's Avatar
I miss my VE
im pretty sure you could run with them if your good enough, stay light, and have all the bolt ons
Old Feb 21, 2008 | 07:13 PM
dineth00i30's Avatar
Gut the **** outta that. Remove the seats, carpets, panels and if. You got the cash get a custom dash done from some light steel and put a nice light seat for you to sit and hit the gym dude loose some weight LOL , jk jk
Old Feb 21, 2008 | 07:19 PM
subs1000w's Avatar
well i really cant one truck stays hooked to a trailer because i have a lawn service the other just gets used as a truck and well the van is not your normal mini its a 5spd and rwd "nobody believes me untill i show it to them" its CRAZY and in the snow and rain its a drift machine its just to rare of a vehicle to give up its main purpose is me and my friends take it on trips and stuff got a 15in drop down tv and what not it really sucks siting 4 or 5 in a car or 5pas suv for 6hours we also load it up with like 8-10pas to go to bars so we only need 1 sober driver
Old Feb 21, 2008 | 07:28 PM
subs1000w's Avatar
your going to have a hell of a time getting 220whp out of a vg30 even a ve is almost imposible to get that much power out of in my opinion it would be cheaper and faster if you turbo it and you wouldnt have to touch the wieght and you wont catch hell for gutting the interior
just think of this you have a gutted max and you race and beat a non-gutted car most of the time hes going to say "oh but you have no interior if i did that to my car i would have won" now ofcourse you still won but i dont like to give people excuses like that
Old Feb 21, 2008 | 08:19 PM
Aaron92SE's Avatar
NWP Engineering.com
My website says "Estimated Horsepower: 310HP at crank and 265 fwhp".
Also, "Curb Weight at track (with driver): 2890 lbs".
Yes, those are estimated with the 75 shot. I use the Dynotune Wet Kit and it provides close to an extra 75whp. When someone says they have a 75 shot, the information you really want to know is what size nitrous jet they are using and at what pressure their bottle is kept at.
But All Motor, my best dyno is 175hp. That was in very poor conditions. I think the motor could have done over 180hp if I wasn't heating it up for over an hour before putting it on the dyno.
But if you want to go fast for cheap, there's only one way. Gut the crap out of the car, remove exhaust components, remove air filter, put in race fuel, and spray a 100 wet shot and hang on!
Old Feb 21, 2008 | 09:25 PM
BenStoked's Avatar
Jesus was a Zombie.
OOPS!!! misquoted! I was in a hurry, and wanted to put it out there. Knew you would chime in eventually, but I wasn't sure when. (and the 265 ft lbs sounded weird, but i put what i thought i saw...)
Old Feb 22, 2008 | 12:00 AM
VEvolution's Avatar
I miss my VE
wow all those bolt ons and you still can only manage around 180 at the wheels? thats barely any difference from stock
Old Feb 22, 2008 | 06:52 AM
Aaron92SE's Avatar
NWP Engineering.com
Wanna line em up? jk
If I was any where close to the stock HP I wouldn't be running 3 seconds faster than stock. And a stock VE auto only makes about 140fwhp. So I estimate I am making around 230hp at the crank.
Old Feb 22, 2008 | 07:05 AM
BenStoked's Avatar
Jesus was a Zombie.
i wanna ve... with bolt ons...
Old Feb 22, 2008 | 07:35 AM
Greeny's Avatar
¯\(°_o)/¯
http://tulsa.craigslist.org/car/570616651.html
Old Feb 22, 2008 | 08:05 AM
mod or sell?
Been there, done that.
Old Feb 22, 2008 | 10:59 AM
VEvolution's Avatar
I miss my VE
yea lets do it, any place, anywhere, anytime.. while im sleepin though.
well you do have a crazy weight reduction plus nos aside from the bolt ons.. so that would account for the 3 seconds. and im pretty sure i saw many people dyno a nearly stock VE on these forums and get around 173fwhp. even one guy was almost stock and got 180. gonna go look for the thread.(i think you chimed in on that thread IIRC) it's about a 15% loss compared to the crank no? 140fwhp is a bit drastic dont you think?
230hp at the crank is pretty sweet tho
Old Feb 22, 2008 | 11:02 AM
VEvolution's Avatar
I miss my VE
looks like cliff getting despreate
Old Feb 22, 2008 | 11:21 AM
Aaron92SE's Avatar
NWP Engineering.com
Remember, I said "VE Auto". They honestly only make 140-145fwhp completely stock. Now the VE 5spd is a completely different beast! It can make high 160s completely stock. I too have seen near stock VE 5spds do 170s. They just had a couple bolt ons and timing advance.
My weight reduction only helps me by about 7 tenths in the 1/4 mile. If I did not do any kind of weight reduction at all, I'd be running somewhere around 14.5-14.6s All Motor in the 1/4 mile. That's pretty impressive for a VE Auto with FULL body weight. Now if I pieced my car back together so it appears to be full body weight, then I'd only lose 2 or 3 tenths in the 1/4 mile. I plan to do this once I see those 11s!
But there's a big difference between what a VE Auto can do and what a VE 5spd can. If someone wanted to, an NA VE 5spd with my modifications can do a 13 flat in the 1/4 mile if not high 12s. All it will take are some large slicks and a good driver. If a VQ 5spd can do it, then a VE 5spd isn't more than a tenth or so behind it with the same mods.
But a VQ30 Auto and a VE Auto are way different. One runs high 15s stock and the other is lucky to run mid 16s stock.
Old Feb 22, 2008 | 11:40 AM
VEvolution's Avatar
I miss my VE
yea i hear ya man. i cant believe the whole thing about auto and 5spd completely slipped my mind
yeah the stock VE auto is a stronger combo then the VQ auto imo
good luck wit those 11's btw
