Replacing my injectors
Old 02-25-2008, 07:40 PM
maxima_man1992's Avatar
Alright so i went and tested my injectors today and well the number 5 injector is open. So it looks like Ill be pretty busy this weekend. Do you guys have any suggestions to make this tune up go alot faster and smoother?
maxima_man1992 is offline
Old 02-26-2008, 07:15 AM
mod or sell?
internetautomar's Avatar
Buy a new car?
seriously though, planing ahead, keeping all tools at arms reach, lights, working indoors
internetautomar is offline
Old 02-26-2008, 07:43 AM
redwood_usa's Avatar
Make sure you have the required gaskets, and do a little extra maintenance while you are there. Change fuel lines connecting rails, change hardened vacuum hoses etc. clean TB, intake plenum etc if not done before
redwood_usa is offline
Old 02-26-2008, 08:02 AM
mikekantor's Avatar
If my experience is anything to go buy, you'll be replacing most of your injectors within the next 6-12 months.
mikekantor is offline
Old 02-26-2008, 08:40 AM
mod or sell?
that's why it is recommended to do all 6 at one shot.
Old 02-26-2008, 09:01 AM
mikekantor's Avatar
That may be extreme for many people, but I would say do all 3 rear ones at once, and save your "working" ones in case the fronts go out.
Old 02-26-2008, 09:09 AM
Alex_V
A VE you can get to the front 3 easily but on the VG all 6 are covered. So for a VG it is very strongly recommended to replace all 6 at once.
~Alex
Old 02-26-2008, 09:12 AM
Buy a new car?
I was gonna buy a new car but now i gotta get this working right.
Old 02-26-2008, 09:21 AM
mod or sell?
~Alex
the OP has a VG, that was the reason for my comment.
the ve is a 45min job on the front injectors
Old 02-26-2008, 09:51 AM
How long do you think it'll take to change them, i wanna see if i can get started on it today after school and maybe have it done tonight.
Old 02-26-2008, 10:04 AM
akurtzer57's Avatar
It can easily be done in an afternoon. Intake might take you 30 45 min if you never have taken it of just to find out what comes of of what. I HIGHLY RECOMMEND SOME VISE GRIPS TO TAKE OF SCREWS ON THE CAPS! If you just use a philips it is likely to strip it out. Before putting intake on cycle key a fey times and let the pump run and check for leaks. I have done this job in just over an hour. (Taken intake off ALOT!)
akurtzer57 is offline
Old 02-26-2008, 10:29 AM
mikekantor's Avatar
on Vise Grips. It can be done with a screwdriver, but its size and shape has to be exactly matched to those screws.
To take the injector out, loosen it by spinning it around a few times, then put one of the screws back in and use it for leverage to pry up against the bottom of the harness connector.
Old 02-26-2008, 11:06 AM
Alex_V
Yea just reminding VE owners its not quite as easy....
I also replaced all the injector cap screws with hex heads I got at a local hardware store. Now they are really easy to get off any time. I really have to get back in there and check all my injector resistances again. Oh well at least it'll be easy.
Any way I think they are 8mm screws or something like that, and using that and a proper wrench is so much easier then the stupid phillips screws they come with.
~Alex
Old 02-26-2008, 11:13 AM
mikekantor's Avatar
I tried to do that last time but didnt find any that matched.
Old 02-26-2008, 11:17 AM
Alex_V
I think its 8mm x 1.25 and maybe 10mm long. I ended up finding them at a really big ace hardware I believe. I'll see if I can find one of the old screws and get the exact measurements....
~Alex
Old 02-26-2008, 11:27 AM
mod or sell?
tap the handle of the screwdriver with a hammer while gently turning the screws. that will loosen them up to be able to come out without stripping the heads.
lowpost99
05-16-2021 11:18 AM
mvm062
11-30-2020 09:00 AM
PH98I30
26
10-12-2015 05:01 AM
TheMafia
09-04-2015 08:26 AM
Quick Reply: Replacing my injectors
