Cleaning MAF sensor (VE30DE)
Old May 5, 2008 | 05:59 PM
R92max's Avatar
Can the MAF sensor easily be removed from the housing to clean? I see there's 4 screws on the housing connector. Don't know if it's possible to remove it to clean it, or if most just spray MAF cleaner through the screen on the end of the MAF housing.
Our car keeps stalling and I think this might be the cause. Cleaning the sensor did the trick for another vehicle I had.
Old May 5, 2008 | 06:28 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
yea just pull the tube off and spray it with maf cleaner through the screen. check the wires for corrosion too. lots of members on here have issues with green crap on their harness plugs and stuff.
Old May 5, 2008 | 07:08 PM
R92max's Avatar
Thanks for the help. I'll try that. Yeah I had some corrossion on the coolant temp sensor connector once and it caused all kinds of trouble.
Old May 5, 2008 | 07:39 PM
Matt93SE's Avatar
STFU n00b!
check the coolant temp sensor conenctions again. possible (and common) culprit.
Old May 5, 2008 | 07:42 PM
xx-Marshall-xx's Avatar
kthxbye2u
check plugs for corrosion
check for vacuum leaks(intake tubes)
my 2 cents
-ReLLiK-
Apr 29, 2016 06:25 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
