stock fog lights
Old May 11, 2008 | 01:54 AM
sams's Avatar
stock fog lights
It looks like my max has stock fog lights?? how do i turn them on to check if they work and if not are they an easy fix?.. thanks a lot again for helping.
Old May 11, 2008 | 02:04 AM
Greeny's Avatar
¯\(°_o)/¯
There is a switch on dash to the left of the steering wheel, next to the cruise control button.
If they don't work, it could be many different reasons why, so......?
Old May 11, 2008 | 03:49 AM
Wiking's Avatar
Originally Posted by sams
...are they an easy fix?.. thanks a lot again for helping.
yes, easy fix.
Old May 11, 2008 | 12:17 PM
XJinCT's Avatar
<3's the all motor section
best part is you can easily hook up aftermarket ones to the stock brackets and wiring, at least thats what i did, and they look OEM. my OEM were cracked and rusted, looked like ****.
Old May 12, 2008 | 01:00 AM
CMax03's Avatar
Check if there is power at the foglight chassis harness... If not, check your fuse... If fuse is installed and good.... Then check that there is a relay installed... check that the switch is powering the relay, and that the relay is operational! If you have power at the foglight chassis harness then check your bulbs! You can do this @ the battery with 1 jumper wire!
As for foglight lense protection, you can apply a clear pressure tape/laminate to the lense. Go to griotsgarage.com, weathertech.com and I believe LaminateX.com...I been using this 40 mil tape on my foglight for yrs without any damage/defects
Old May 12, 2008 | 12:10 PM
sams's Avatar
my Max has the spot for fogliths and the litlte glass housing but i do not have fog lights as an option .the botton is simply black and does not have the fog light picture on it. Can i still install fog lights in the original maxima fog light area???
Old May 12, 2008 | 12:22 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
yea you can install stock fogs. you should be prewired for it on the bumper, and some-but-not-all GXEs were prewired for the switch on the dash. so undo your switch panel and see if there's another harness lurking back there. if it is, just toss in a relay, hook up some fogs and a JY fog switch from an SE and drive happy.
Old May 12, 2008 | 02:46 PM
sams's Avatar
http://www.canadiantire.ca/browse/pr...romSearch=true
Can these be mounted easily/ whats the set up process? will the fog lights come on when i turn the headlights or will i have to make some switch.. remeber my max does not have a button for fog lights. also i want a fog light with a color that will sorta match my maxima stock headlights .. thanks
Old May 12, 2008 | 03:23 PM
BenStoked's Avatar
Jesus was a Zombie.
sure. but if the wiring isn't there, it will make it more difficult, as you will need to make the harness... not a hard process.
Old May 12, 2008 | 04:44 PM
DBooker_93GXE's Avatar
i've been seriously thinking about installing some fogs up to my gxe, but was trying to think about the planning i might need to do....but now....how would i find the wiring for fogs on my gxe at the bumper area(if its there)....and i'm thinking that i do have the wiring up at my dash (i've taken that apart before)
Old May 13, 2008 | 11:09 PM
CMax03's Avatar
foglights
Call Courtesy Nissan and ask how much a foglight kit may cost for a 3rd Gen! Should include foglight assys, switch ,relay. Or search the bone yards for those various parts!
Old May 14, 2008 | 07:24 AM
foglight harness circled in red. on a non-fog-equipped car that DOES have the wiring, it will be doubled back into the little burgundy cap you see a the top of the red 'circle' i drew. the plug itself was too far down on the pictured fog-equipped max to actually show up in the picture i took... it's just down in the bumper.
note: engine and transmission removal NOT necessary to access foglight harness
Last edited by CapedCadaver; May 21, 2008 at 07:47 AM. Reason: pic link changed. had to fix.
Old May 20, 2008 | 10:35 PM
Chokko3131's Avatar
My fog light seems to not work, well the left works the right doesnt and the left headlight does not work and the right does? Where are the fuses inside the car for the headlights, i have check the ones under the hood. Thanks
Old May 20, 2008 | 11:03 PM
CMax03's Avatar
Well the fuse panel is just above the hood release handle l/h side of your dash! Since 1 is working, I know your fuse is good! Just check the connector @ the foglight for power. More than likely a burnt bulb! Do the same for your headlights or swap the l/h and r/h bulbs...I believe you can figure that out right?
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
