What Is The Correct Torque For Fuel Injection Hose Clamps?
Old May 11, 2008 | 10:29 PM
1993-VG30E-GXE's Avatar
In FOOT-LBS?
Old May 12, 2008 | 12:14 AM
Wiking's Avatar
Originally Posted by 1993-VG30E-GXE
In FOOT-LBS?
In handlbs: take bag full of clamps, tighten one as fast as u can - crack. Then next, tighten little bit little less... repeat until theyre crakin no more - voila' ... the right lbs was found.
Old May 12, 2008 | 12:38 AM
CMax03's Avatar
In FOOT-LBS?
How about inch-pounds? Or how about just tighten them until the hose can't rotate anymore! If your rubber is squeezing thru the band, then you probably need to replace your hoses (soft)! Are you gonna need the torque values for the bumper signal light screws next?
Old May 12, 2008 | 12:42 AM
Hectic's Avatar
.7-1.1 ft-lbs
Old May 12, 2008 | 06:07 AM
internetautomar's Avatar
mod or sell?
fuel injection clamps don't have slots in them for the rubber to squeeze through and be damaged.
Old May 12, 2008 | 06:52 AM
CMax03's Avatar
Get the clamp as close to the swage and tighten until you can't rotate the hose on the pipe! Leak check by turning on ignition switch and check for leaks!
Old May 12, 2008 | 11:18 AM
Actually, would you happen to have the torque value for my key in the ignition? In Inch-lb?
Old May 12, 2008 | 11:21 AM
Really? No need to have the car running? I'm pretty sure I see it leaking after it has started. I notice in the manual it says in the last step of installing the injectors to test for leaks - but I don't see how this is possible without closing everything up and re-connecting everything.
Old May 12, 2008 | 11:32 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
sense of humor FTW
anyhow the fuel pump WILL run and the line WILL pressurize just by putting everything together and turning the key to ON. it'll do that for like 10 seconds then shut off. no need to actually crank it.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
