antenna motor
Old May 15, 2008 | 12:39 PM
sams's Avatar
antenna motor
My car antenna's motor now grinds for about 10-15 seconds each time i turn on my stereo. The mast/antenna works fine i can pull it up and down with my hand but the motor for the mast seems like the gears are stripped or something... WHAT cord can i cut just to disable the motor for the antenna??? because i get good reception even with the antenna down.
Please help the sound is driving me crazy.
Old May 15, 2008 | 12:42 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
does the motor still move the mast? you said it 'still works' ... it shouldn't be easy to push or pull it by hand. it should take considerable force. and yea it's possible for the teeth on the mast thing to be stripped. if you want to turn it off there's a harness plug on the antenna motor you can unplug. just don't unplug the antenna's signal wire.
Old May 15, 2008 | 12:55 PM
sams's Avatar
thank you but i have a 1994 and it seems so hard to get to the antenna. Its behind a huge metal plate even after i take the trunk lining off???? to unplug it .any help????? thanks
Old May 15, 2008 | 01:03 PM
it's the same regardless of year. very few things are year-dependent or model-dependent. to take the antenna out you unscrew the shiny plastic nut at the top but to unplug the motor you just reach down in there after removing the jack.. i think it's on the bottom of the motor assembly.
Old May 15, 2008 | 01:45 PM
sams's Avatar
i see a BLUE cord that seems like it is attached to the antenna motor but it has no harness on the motor side but it goes down to this lil plastic box an inch away that has a few other wires coming out does the blue wire control the antenna motor only because im just going to cut it is that a bad idea?
Old May 15, 2008 | 01:58 PM
shoult's Avatar
Don't CUT ANYTHING!!!!
There is a plug. My Max and my FSM are both at home, but I KNOW there is a plug.
Old May 15, 2008 | 01:59 PM
i highly advise against cutting anything. just hold off for an hour.. i'll look at my car when i get home and take a pic or two.
Old May 15, 2008 | 02:12 PM
BenStoked's Avatar
Jesus was a Zombie.
I just checked, there are two harnesses going into the box(i believe). unplug the one closest to the fender, it should have two wires for power. just make sure the mast is fully down.
Old May 15, 2008 | 03:55 PM
sams's Avatar
ok so the blue wraped wire the one closest i cut... it was a bad idea.. . my after market radio won't power on and my clock does not work? how do i fix this and what the **** did i do??? should i just put the wires back together??
ps ..i checked the fuse for the radio so i dont know what it could be
Old May 15, 2008 | 05:07 PM
why did you even bother posting a post on here if you NEVER PLANNED TO LISTEN?! we told you, and i quote
yet you don't seem to have the mental capacity to listen. you don't even deserve our help at this point. I even went out to my car, IN THE RAIN, to take a ****ing picture for you. but NOPE you were too trigger happy to even give me a chance to post the damn picture? do you think before you do things?
Old May 15, 2008 | 05:35 PM
see? if you could have just waited for me to get back from my errand, you would have seen this picture, seen that from the time you unlock your trunk to the time you have an unplugged antenna, it takes about 45 seconds IF you still have your jack in the way. see that yellow thing. unplug that. that's it. no cutting. no whining. no looking like a n00btard.
Old May 15, 2008 | 06:41 PM
sams's Avatar
you dont have to be a **** about it. it was cut before anyone posted anything. and to second your comment that picture dosent resemble my antenna at all it is a 1994 special edition with keyless entry and there is a totaly different set up....
Old May 15, 2008 | 06:46 PM
shoult's Avatar
This is the same guy that started the
http://forums.maxima.org/showthread....143&highlight=
thread and many different versions of it after he didn't get the answer he wanted.
Old May 15, 2008 | 07:30 PM
BenStoked's Avatar
Jesus was a Zombie.
I don't like to be a **** to people i don't know,but:
...you asked a question, and it was answered in less than 15 minutes. why would you ask if you would not be willing to wait a couple of hours tops, usually.
so what does your antenna look like?
mebe there is something that can be salvaged from this...
Old May 15, 2008 | 07:34 PM
what exactly is a "special edition"? is your keyless entry a remote or on the door handles? i know canada had a brougham... people really need to include their location under their avatar, 1) to suggest where nearby org members are and 2) so we know if your country's max is a little bit different. as much as you like to think you know 'everything about your car' and its specifications if we don't know what you're talking about, chances are you don't either. are you sure you even have Nissan parts in your antenna area? if they are non-oem stuff that could be part of the problem
also can you take any pics? of the "blue" thing you cut? and also take that pic i took for you, angled into the fender where the antenna goes. if it's not, did you reach underneath and feel for wires? FSM shows them pointing up, so maybe i was wrong about the year not mattering, but still, we told you not to cut anything over 2 hours before you came back and said you cut it anyways
Old May 16, 2008 | 04:11 PM
internetautomar's Avatar
mod or sell?
nissan made "limited editions" of the sentra in 94 (actually late run 94s when 95 production was started)
Special edition to me is an SE, but once you add keyless it gets confusing.
Post up a VIN so we can see what you got.
you can blank out the last 6 digits to be safe.
Old May 16, 2008 | 04:58 PM
shoult's Avatar
A "brougham" is nothing more the a gussied up non-SE. The is just a Maxima, loaded, nothing more. They engineers in Japan didn't stand there and say, "Hey, this is a top level Canada only car. We have to do something different for the antenna, especially since Canada is our highest volume market!".
It's just a power antenna. Unless there were major design flaws in the original unit (there wasn't) or a major re-design of the body shell (there wasn't) then there would be no reason to change the antenna one d*mn bit, no matter how gussied up of a model it's installed in.
DON'T CUT THE WIRES!!!!!!!!!
Oh, sorry. You already did.
Old May 16, 2008 | 07:10 PM
i must submit that i was wrong on ONE thing. which makes Sams not-quite-as-dumb for cutting the wire, but he was right about something that i was wrong about. there WERE two antenna styles. Bose and non-Bose. I just looked at both my SEs, and they were the blue-cord-type, whereas my GXE has the style pictured. but i was also right about something that i thought i was wrong about - the thing you unplug is UNDER the antenna box. take jack out, reach UNDER jack support, palm-up with your index finger at the front, push the tab, grasp the harness between finger and thumb and pull it down. i have a pic.
and yea i know my arms are ape-like . It's a Me n' Wayne thing. Me n' Wayne.
Old May 18, 2008 | 08:25 PM
astandupguy's Avatar
Just Curious. With the antenna motor not working properly does the motor create a draw on the battery when the key is in the off position?
Old May 18, 2008 | 08:36 PM
none that i'm aware of. when the motor is malfunctioning, it's isolated to the motor itself. the controller box actuall decides when and how the motor gets juice. if the mast is broken (more common) that's a physical issue, not electrical
Old May 19, 2008 | 06:03 AM
mod or sell?
considering that a motor itself will only be considered failed when it no longer turns, then at that point it will no longer be drawing current.
the antenna however can be considered failed once it no longer goes up or down, however the motor can still be turning at that point and drawing current.
AaronL
Aug 8, 2020 10:31 AM
chisam14
Nov 6, 2018 08:56 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
