sunroof help
sunroof help
hey guys i need ur help again. i have a 90 max SE and the sliding cloth thing that is inside doesnt slide in. and when i try to open my sunroof it gets caught and jams my sunroof. how can i fix this?? cause that piece wont slide, only like an inch so i cant open my sunroof thanks
Sunroof shade removal
Originally posted by Maxima90SE
when u do find out and how much is it to fix please let me know thanks
Here is how to remove it You have to take the glass off first (it is not hard, takes about 10 minutes to do.):
1. Slide it back.
2. Open the sunroof to the position where it is popped-up (not slid back)
3. There are 2 plastic bolt covers (one on each side) on the glass. Each one has one screw in it. Remove the screw, and the cover should slide back and come off.
4. Remove the nuts that hold the glass. Remove the glass by picking it up from outside the car.
5. Slide the shade forward about half way. Get out of the car and work from the top. Notice the black clips on the sides that ride on the aluminum rail. There are four of these, one set on each corner. Be very careful here (I am not interested in this part if all 4 of these clips are not intact): Remove both of the front ones, and push the front of the shade downward so that the clips do not re-engage.
6. Pull the shade out further and repeat for the rear clips.
Well..
my clips on the shade thing are broken!! and the shade thing is like bend, it curves from left side to the right side
You can get one from a junkyard, or you can buy a new one from Courtesy. With the maxima.org discount, it runs about $120.
You can just take it out, but the shade completes the seal on the sunroof by lifting the windows a little. So you'll have to deal with the sun shining on you all the time, and when you go to automatic car washes, you may get a small spray. I think that you can lift the roof a little to compensate for the missing shade though.
Forge277
Jun 13, 2016 09:26 PM
