Broken intake gasket
Awhile back I went to the dealer to pick up one of those plenum gaskets and part of 1 or 2 of the rubber seals was scratched off, I asked for a different one and the parts guy laughed and said it wouldn't be a problem. So I told him I wanted a different one, then he went and got one for me.
installed the gaskets as per the order in the chiltons manual and to torque specs. I'm still having the same problem. When the car idles, the needle on the tach sometimes dip from 700 to 500 and back up then it settle at 650-700. The car feels like its choking. I checked all the vacuum lines,change the ones that were bad, but no effect. I'm pissed off now because this is 2 days I've been working on the damn thing.
the weird thing is that before I started the work, the car was idling very smooth. not a vibration. I heard of someone saying to put a screwdriver on the injector and listen for any ticking, I did and there is ticking on all six.
to the OP
the idle is within normal range but it's not smooth is what I am gathering from you.
Clean the IAC. if that doesn't help then if you want to start looking for vacuum leaks use a small propane tank with a hose (carb cleaner works too) and slowly spray around areas of the intake and see if the idle smooths out at any point. If it does, then you found the location of a vacuum leak.
there are alot of air leaks possible on a VG30E, Not only the lower manifold to head gasket but, the lower manifold to lower plenum adapter plate, the lower adapter plate to upper plenum and 2 more spots, fwd of the throttle and aft of the throttle plate. Break out a hose to listen for any air leaks around the intake system!
I had a loose clamp on the right fuel hose near the EGR valve. so I had to remove the planum and the adapter plate. so I decided to change the gaskets. the one for the plenum and the adapter plate. How many vacuum hoses does the VG have. I checked them all or am I missing some?
litch
123
01-04-2024 07:01 PM
tarun900
19
12-20-2021 06:57 PM
knight_yyz
11-01-2015 01:34 PM
