ECU diagnose
ECU diagnose
can someone explain me in details that how to pull out codes from 1992 maxima se (VE)? cuz weneva i try to pull codes out all i see mah ecu doing....6 red flashes slowly and 6 red flahses fast......and it keeps doing that again and again no change.....wat does that mean?
heh yea i read the OP's post too quick the first time. flashing is how the ecu tells you what number code you have. long flashes (on a VE... or red for VG) are the tens place, and short flashes (on a VE... or green for a VG) are the ones place. so ___ ___ ___ - - - - would be 34. ___ ___ would be 20. ___ ___ ___ ___ ___ - - - - - is what you want to see. i didn't know our ecus were smart enough to indicate which cylinder was misfiring... unless it reads a totally broken coil on that injector, thus, no continuity.
sorry guys i was mistaken.... i jus pulled codes again its not 6 its 5 long flashes and 5 short flashes and thats wat it keep doin it...and i jus checked those codes and thats
Normal engine management system operation is indicated.
thats normal rite?
thats normal rite?
tarun900
19
12-20-2021 06:57 PM
Omar Abdurrahman Siddiqi
08-26-2016 05:18 PM
QueensMAX
09-15-2015 04:14 AM
