View Poll Results: What should I get ?
HID on my stock OEM housing
27.27%
E36 projectors
24
72.73%
Voters: 33. You may not vote on this poll
Should I Get HID's or E36 Projectors
Old Sep 9, 2009 | 07:58 PM
  #41
ustfdes's Avatar
- Product of Maxima.org -
Originally Posted by tresboi
actual 3rd Gen Cefiro retro!
wat
Old Sep 9, 2009 | 09:51 PM
  #42
tresboi's Avatar
Originally Posted by ustfdes
wat
LOL sorry, I was referring to your sig pic... it's an actual Cefiro retro in a 3rd Gen (and looks great, too!)
Old Sep 10, 2009 | 09:33 PM
  #43
ustfdes's Avatar
wat? it's impossible!
Old Sep 11, 2009 | 12:47 AM
  #44
EsQueue's Avatar
would a small capacitor for the headlights be a good idea then?
A relayed wire harness should do just fine.
1995-1999 nissan maximas and infiniti i30s have a 3 pin socket (9004). A common, low and high. I am pretty damn sure that this is the same for nearly all nissan/infinity vechiles. Test the lights with a multi meter and see if you get the results I get below. I posted the following on hidplanet. I also posted a schmatic that I made in ms paint by a combination of cutting, rotating and pasting.
While off, all pins are dead.
During low beam operation, the common pin will be positive (+), the low beam pin will be negative (-) and the high beam will be dead.
During high beam operation, the common pin will be positive (+), the low beam pin was positive (+) for some damn reason and the high beam pin will be negative (-).
They use a common positive (+) and a ground to switch the lights on hence the name "ground switched".
If wiring a harness use the common (+) and a chasis ground (-) to activate the main ballast relay as common is only on during headlight operation. No need to use the low beam connector at all especially with it's switching polarity LOL. For high beam You can use the common (+) and the high beam (-) to power that relay.
Old Sep 16, 2009 | 06:54 PM
  #45
Stwodahorty's Avatar
both!
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Mochedda
Dec 15, 2015 11:27 AM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
