Radiator Fan Won't Start
Old Jul 18, 2008 | 07:41 PM
xnos's Avatar
Hey,
It its 100F here in NJ and my car doesn't seem to like that weather. I was driving for an hour to philly today and on the way back my car began to over heat. I stopped checked the hood ... waited a while and my rad. fans wouldn't start. At the end I ended up connecting my fan directly to the battery and driving home.
With my car I have noticed that when it gets really hot my fan seems to stop working. The mechanic at Nissan told me before that it is probably a problem with the ECU. But I am thinking its a sensor ? what do you guys think ?
thanks a mil.
Old Jul 18, 2008 | 07:50 PM
jojo98maxima
ur right its got to be a sensor or belive it or not check the fuse
Old Jul 18, 2008 | 08:33 PM
burhan92SE's Avatar
it could be your coolant temperature sensor....it defiantly should be if ur fuse is gud....
Old Jul 18, 2008 | 08:55 PM
xnos's Avatar
Hey, all the fuses and relays are good. I did some research and it has to be the Coolant Temperature Sensor. Today my car was even choking from too much fuel. thanks!
I will fix it tomorrow.
Old Jul 18, 2008 | 09:05 PM
xnos's Avatar
BTW. I forgot to mention that when I was accelerating in the heat today the engine was very week and was making a rattling sound as if I was dragging a piece of metal (scraping the ground). This sound only occurred when I pressed the gas. When I fixed the fan, and the temp went down, the noise went away.
Old Jul 18, 2008 | 09:10 PM
jojo98maxima
keep us posted good luck broo
Old Jul 18, 2008 | 09:13 PM
burhan92SE's Avatar
kool...i knew it that it was CTS....90% of the time it is CTS...so gud luck and have fun changing it..its easy to change...
Old Jul 19, 2008 | 11:40 AM
xnos's Avatar
thanks. BTW should I use any sealant or lubricant when installing it ? or just directly install it ?
Old Jul 19, 2008 | 01:42 PM
burhan92SE's Avatar
when u will buy a new Coolant temp sensor u will get new seals with it, just use them and u r gud to go...but remember when u change ur CTS ur engine should be cold other wise u might get burned by HOT coolant cuz wen u take old CTS out coolant gonna come outta there...so let ur engine cool down then change it....ur cooling system will work alot better with new CTS.....if u will have any problems just post it here and we will help u
Old Jul 19, 2008 | 04:59 PM
xnos's Avatar
thanks for all the help. I changed the sensor today and my car runs great now. Not only does the fan work well, but it revs very clean now. thanks!!!
Old Jul 19, 2008 | 06:15 PM
burhan92SE's Avatar
glad to hear...that ur problem is solved....have fun
captchaos
Mar 15, 2016 12:18 PM
Smackasmith
Feb 1, 2016 12:40 AM
markevans999
Sep 10, 2015 04:29 PM
Hdnseek
Sep 9, 2015 05:55 AM
trungg86
Sep 4, 2015 04:58 AM
