Wider tire?
Old Jul 20, 2008 | 11:59 PM
burhan92SE's Avatar
Wider tire?
i m getting new set of rims and tires....but before buy i wanted to know that can i put wider tires than stock tires on maxima? if i can then whats the maximum limit of wider tires i can go for?....
Old Jul 21, 2008 | 02:16 AM
maxima-junky's Avatar
Wide tires
I had some 245 50 17s on my vg it wasn't dropped though. I have 235 40 18s on my ve thats dropped on Eibachs and planning to put some 245s in the back soon.
Old Jul 21, 2008 | 06:21 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
if i may ask... why put wider rubber on the back end of a FWD car? if anything wouldn't you want to neutral the handling out a tiny bit by having more front grip than rear?
Old Jul 21, 2008 | 06:47 AM
300zmax's Avatar
you may improve rear handling on a track day car with bigger tires in the back if you had a huge whale tail wing in the back other than that maybe it would look good. hell tub out the back, put in a set of slicks and make everyone think it rear wheel drive.
Old Jul 21, 2008 | 07:08 AM
i was just thinking in terms of RWD->oversteer and FWD->understeer... personally i've never lost the rear end of my car. the front, yes, but the backend, no. so i'd sacrifice a little rear grip if it meant the car would rotate a little bit better. (as for tubbing....my uncle has a tubbed out slicked-up mustang that breaks 7's. 30x12.0R15 slicks out back and skinnies up front, 300shot on a 427 motor.)
Old Jul 21, 2008 | 07:56 AM
I put wider tires on the back of a fwd car strictly for cosmedics.
Old Jul 21, 2008 | 08:21 AM
that's pretty much what i figured. though the more rubber hitting the road, the more braking force you can apply before locking up. just warn the passengers before slamming the pedal haha.
Old Jul 21, 2008 | 03:06 PM
3g94MaxGXE's Avatar
Oh definitely. My brakes are enough to **** people off and pretty sure my dad just walked into advance and asked for brakepads about 6 years ago and thats whats on there. No fancy pads, nice rotors, etc.
Old Jul 21, 2008 | 06:17 PM
burhan92SE's Avatar
wider tires on the back and normal on the front, like M3...would dat make handling any better?.....does that make sense?
Old Jul 21, 2008 | 06:39 PM
BenStoked's Avatar
Jesus was a Zombie.
no.
Old Jul 21, 2008 | 07:26 PM
burhan92SE's Avatar
Old Jul 22, 2008 | 04:19 AM
BenStoked's Avatar
Jesus was a Zombie.
no, on topic; you asked if you made sense, I said "no"
Old Jul 22, 2008 | 06:00 AM
slay
thing is, the front tires do all the work. so worry about the front.
Old Jul 23, 2008 | 06:11 PM
CMax03's Avatar
measure your vehicle with the wheels off and get a string with a plumbob or weight and a tape measure. Start with the distance from the hub to the fender lip and from the fender lip to the strut. You'll know how wide of a wheel it can take and just figure in your offset with your measurement you just took.
Alot of guys like the flush look (wheels even with fender), I personally like to leave 1/2-3/4" clearance so I can lower the suspension and have no rubbing at all. My 3rd Gen is running 17x7.5" wheels with 225/45/17 tires and 1.5" dropped ST springs!
Old Jul 23, 2008 | 06:28 PM
burhan92SE's Avatar
ya only u dont understand others do so watever....
thanks to capedcadaver and CMax03
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
