I was driving and...
Old Aug 5, 2008 | 06:13 PM
  #41
3g94MaxGXE's Avatar
Originally Posted by 505max94se
JB weld
You've GOT to be kidding...
Old Aug 5, 2008 | 06:43 PM
  #42
505max94se's Avatar
No I'm serious. I have alot of equipment to weld steel, but nothing to weld aluminum and the only way to weld steel to aluminum is with jb weld, afaik...
IMO, there's nothing wrong with using JB Weld for stuff like this. It won't break and it's not like you'll be able to tell what I used to weld it once it's cleaned up and painted.
Old Aug 5, 2008 | 07:08 PM
  #43
3g94MaxGXE's Avatar
I'd at least use some flanges and bolts to hold it together. Just weld a steel flange onto the steel side and an aluminum one to the aluminum side.
I just don't believe in holding things like this together with something that comes in a tube. I don't mind that sort of stuff as a secondary measure or seal but nothing beats a good solid bolt for holding things together.
Old Aug 5, 2008 | 07:15 PM
  #44
ColombianMax's Avatar
...nothing beats a good solid bolt for holding things together.
meh that's what i said and then my radiator fell
Old Aug 5, 2008 | 08:21 PM
  #45
505max94se's Avatar
Please tell me whats wrong with using JB weld for something un-structural like an intake manifold. It's not like I'm boosted... Plus, wouldn't bolts and a flange look "ugly." lol
FYI, I've seen cracked engine blocks that had been repaired with jb weld. I also have seen them run with out leaks.
Old Aug 5, 2008 | 08:23 PM
  #46
505max94se's Avatar
should have used jb weld
Old Aug 5, 2008 | 08:28 PM
  #47
believe it or not...it fixed my pathfinders harmonic balancer/crank pulley widened gap Yes even worked on a moving part!
Old Aug 5, 2008 | 08:37 PM
  #48
505max94se's Avatar
Old Aug 5, 2008 | 08:59 PM
  #49
So umm whens your estimated time for completion?
Old Aug 5, 2008 | 10:39 PM
  #50
3g94MaxGXE's Avatar
good bolts look sexy
Old Aug 5, 2008 | 10:51 PM
  #51
505max94se's Avatar
a couple of days
Old Aug 6, 2008 | 12:59 AM
  #52
CMax03's Avatar
Why not fab all of it out of aluminum? How about a full round 4"-5" plemun?
Old Aug 6, 2008 | 09:04 AM
  #53
505max94se's Avatar
I stated earlier in the thread that I don't have equipment to weld aluminum. Full round would starve the cylinders that are further away from the TB and more plenum volume would shift the powerband even further to the right.
Old Aug 10, 2008 | 11:13 AM
  #54
505max94se's Avatar
Just an update... I would be able to finish the project today, but I'm going out of town for a couple of weeks.
  #55
505max94se's Avatar
Old Aug 10, 2008 | 12:22 PM
  #56
coolsun's Avatar
the gasket looks like its made of wood?
Old Aug 10, 2008 | 12:40 PM
  #57
505max94se's Avatar
lol, it's phenolic...
Old Aug 10, 2008 | 12:58 PM
  #58
BenStoked's Avatar
Jesus was a Zombie.
good. you scared me, too. I thought you were
Old Aug 30, 2008 | 06:00 PM
  #59
James92SE's Avatar
2 VE's are better than one!
Updates?
Old Aug 30, 2008 | 06:47 PM
  #60
505max94se's Avatar
Updates?
I should have some updates in a few days. I've been busy getting my other car ready to be shipped to WA.
Old Apr 16, 2009 | 03:19 PM
  #61
505max94se's Avatar
  #62
505max94se's Avatar
Old Apr 16, 2009 | 03:34 PM
  #63
kringle03's Avatar
Impressive!... Did you loose the low end torque as thought?
Old Apr 16, 2009 | 03:39 PM
  #64
505max94se's Avatar
The low end is not that bad. I mostly lost mid range power, but it screams from 5500 to 6500. I really need to raise the rev limiter to take full advantage of this manifold.
Old Apr 16, 2009 | 03:43 PM
  #65
505max94se's Avatar
BTW, my 150 shot jets arrived today....
Old Apr 16, 2009 | 03:45 PM
  #66
Jeff92se's Avatar
I'm needing a caw
Awesome work! Gold member!
Old Apr 16, 2009 | 03:50 PM
  #67
505max94se's Avatar
Thanks!
Old Apr 16, 2009 | 03:52 PM
  #68
James92SE's Avatar
Wow, that's pretty cool. Really makes the engine look different too. The rear coil packs look funny sticking up like that
How about a video of a nice downshift to 3rd gear at 75 mph run?
*edit* Hmm could you also now maybe run front coil packs on the rear valve cover?
Old Apr 16, 2009 | 03:56 PM
  #69
505max94se's Avatar
With spray?
*edit* Hmm could you also now maybe run front coil packs on the rear manifold?
Nope, I already tried that, they don't fit.
Old Apr 16, 2009 | 05:12 PM
  #70
CapedCadaver's Avatar
Call me Wookiee Goldberg
nice work! one of the coolest custom mechanical (ie, not electrical) parts i've seen in a while. wish you had an on-car dyno so we could see before/after runs. On a scale of 1-10 how good would someone's fab skills have to be to make that theirself?
Old Apr 16, 2009 | 06:12 PM
  #71
Greeny's Avatar
¯\(°_o)/¯
Oh my!
Old Apr 16, 2009 | 06:19 PM
  #72
505max94se's Avatar
Thanks!
IDK, It was pretty difficult, especially the way I did it. If I had a tig welder and spent money on proper materials it would have been much easier.
Old Apr 16, 2009 | 06:20 PM
  #73
505max94se's Avatar
Originally Posted by Greeny
Oh my!
Old Apr 16, 2009 | 06:42 PM
  #74
goon9's Avatar
I'm glad to see it happen! Hope the jb holds up, I've never used the stuff so I'm naturally a skeptic. Look really great!
Old Apr 16, 2009 | 06:58 PM
  #75
Thanks!
you mean like using an aluminum plenum adapter plate rather than a steel one? or was that aluminum but the plenum itself was steel?
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
Pixel
Sep 15, 2015 05:53 AM
Maxie40
Sep 14, 2015 11:28 AM
