Front sway bar/suspension poly bushings?
Old Nov 6, 2001 | 11:19 PM
Evil Yak's Avatar
Anybody know who makes them or where i can get them?
Thanks doods!
Old Nov 7, 2001 | 07:18 AM
Matt93SE's Avatar
STFU n00b!
suspension techniques has poly bushings for their front sway bar.. the parts SHOULD fit on a stock bar also.. I believe the parts are made by energy suspension, but I'm not positive on that.. they're the typical bright red color of the energy bushings.
give them a shout and see what you can find.
(and while you've got the sway bar off, why don't you just replace it with a suspension tech bar? you'll be glad you did! )
as for the control arm bushings, those are only the black rubber OEM jobs. nobody makes any others.
Old Nov 7, 2001 | 10:46 AM
maxmizd27's Avatar
Those bushings will fit the stock front bar also. The ST bars are the same outside diameter as the stock bars. The difference is that they are solid instead of hollow.
Old Nov 7, 2001 | 11:01 AM
Bman's Avatar
Are you sure? That thing is HOLLOW? Man, here I was looking at that huge thing (no matter how weirdly shaped) and nodding appreciatively at its diameter...
Old Nov 7, 2001 | 11:35 AM
maxmizd27's Avatar
The stock bar is hollow, yes. You'll understand when you get that ST bar in your hands. It must weigh close to 20 pounds!
Old Nov 7, 2001 | 12:04 PM
MadMaxBrent's Avatar
It is hollow on mine. One side is squashed where the car has hit something real hard by a previous owner.
Brent.
Old Nov 7, 2001 | 12:57 PM
Bman's Avatar
Hmmm, so that means if I were to get the ST front sway bar... and the Addco rear sway bar...
Old Nov 7, 2001 | 12:59 PM
maxmizd27's Avatar
Don't know if you can get just the front ST bar. Mine came as a kit. Front, rear, bushings and all mounting hardware.
Old Nov 7, 2001 | 01:03 PM
Bman's Avatar
Oh well, doesn't matter now anyway. This would all be sometime next year at earliest. Just thinking.
wyobbagy
Jan 3, 2023 12:03 PM
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
jfl330
Sep 4, 2015 01:44 PM
